Warning message
Wireless Design help needed
May 8th, 2012
We have 4402 controllers with (6) 1242AP's and I'm wondering would it be beneficial to add a couple more AP's to our network to accomodate more users that are coming in or design for a new platform?
I'm not sure what the costs may be to go to a new controller based platform or what AP's would be best (1130's?).
Can onyone provide some insight not in depth but ballpark figures.
thanks.
Leo Laohoo Tue, 05/08/2012 - 15:50
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Yes.
Depends on your budget.  The most affordable WAP that only supports 802.11a/b/g is the 1130.  If you want to support 802.11 a/b/g/n then you should be looking at the 1040.
You need to ask your nearest authorized Cisco reseller.  Get a quote from at least three of them so you know what you're up against.
If you still think they are pricey, then try Cisco Refurbished
vishal.rane Tue, 05/08/2012 - 23:25
Hi leo
how do you distinguise between cisco new product and refurbished product
( anyway to distinguise between them, i.e part no .... or any other method )
thanks
Vishal
Leo Laohoo Wed, 05/09/2012 - 16:03
  • Hall of Fame,
    2017 LAN, Wireless
Look at the Product ID of the appliance or the box.  Refurbished have the suffix of "-R" or "-Ref".
Related Content
