Warning message
Two Host on the same subnet connected to two Cisco routers
Answered Question
May 9th, 2012
Please refer on the attached file. PING is unsuccesful for both pc. What routing protocol that I'm going to use here? I tried RIPv2 but I still a "Request timed out" message.  -- The concept of this topology will be used in a larger network setup.. Please help..
R1(RIP)
network: 192.168.0.0 & 10.0.0.0
R2 (RIP)
Correct Answer by Giuseppe Larosa about 5 years 3 months ago
Hello Mark,
what you are looking for is an OSI Layer 2 transport service over an IP routed network.
No routing protocol can give you this.
L2TPv3 can be useful in these cases but you have to be aware that all broadcast, multicast and unknown unicast traffic will be carried over the WAN consuming bandwidth
see
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t2/feature/guide/gtl2tpv3.html
it is supported on ISR routers like C3725 or C2800 with appropriate feature set.
A routed solution with different IP subnets at the two sites should be preferred if possible.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Mandlenkosi Nkiwane Wed, 05/09/2012 - 09:49
  • Bronze, 100 points or more
Can you change the end networks to make them different subnets?
Henrik Grankvist Wed, 05/09/2012 - 09:54
  • Silver, 250 points or more
It won't work because they use the same subnet on two different locations.
Change one of the networks to 192.168.1.0/24 or something similar.
Correct Answer
Giuseppe Larosa Wed, 05/09/2012 - 09:56
  • Hall of Fame,
    Founding Member
Hello Mark,
see
Hope to help
Giuseppe
mactej6228 Wed, 05/09/2012 - 11:02
Thanks for all your replies it give me some insights...
Related Content
