7937 external mic extension cord
Answered Question
Does anyone know if there is any kind of longer or extension cord for the external mics on the 7937?  From what I understand the original cords are 5' long and the connections of proprietary.
I have a site where they want to run the cords under the table instead of having them strung out across.
I've seen that polycom makes a $400 lapel mic that will work, but that sounds expensive.
Has anyone dealt with this?
Thank you!
Correct Answer by Rob Huffman about 5 years 2 months ago
Hi Malcom,
The Cisco 7937 is a re-branded Polycom Soundstation 7000. If you Google this part# you will find lots of hits for the 25 foot replacement mic kit cables (pretty cheap as well
polycom 2200-40017-003 for 25 footer
Here is a picture of the Polycom Soundstation 7000;
http://www.polycom.com/usa/en/products/voice/conferencing_solutions/conference_phones/soundstation/soundstation_ip7000.html
Cheers!
Rob
"Everything is broken" - Bob Dylan
Overall Rating: 5 (3 ratings)
Correct Answer
Rob Huffman Wed, 05/09/2012 - 11:49
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Malcom,
Cheers!
Rob
chrisnoon11 Tue, 07/10/2012 - 06:23
Rob,
Do you know if that 25ft extension cable will also work with a 7936?  I believe that it is a rebranded Soundstation IP 6000, but I could not find any indication whether the 6000 and 7000 can use the same external mic cables.  Appreciate your help.
--Chris
Rob Huffman Tue, 07/10/2012 - 07:24
  • Hall of Fame,
    Founding Member
Hey Chris,
The connectors are quite different between the 7936 and 7937 so
the part listed above won't work for your 7936's. I believe you would
need the part listed below instead ;
Polycom Microphone Cable 2200-00675-003
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
Related Content
