Warning message
Upgrading IOS on 6500 with redundant Sup 720s
Answered Question
May 9th, 2012
Hello ALL,
I sort of messed up and upgraded the IOS on one supervisor on a 6500 without doing the second, saved and reloaded.   How to I get the 2nd one working again?  When I issued a show module the "normal" Active sup shows active and the standby shows as Supervisor-Other      Unknown       Unknown
Any help you can provide is greatly appreciated
Correct Answer by Leo Laohoo about 5 years 3 months ago
"Unknown" possibly means the supervisor card is in ROMmon.
The fastest way to move the IOS from one Supervisor card to the other is via compact flash (CF).  Once you insert the CF into the supervisor card that's in ROMmon you can force this card to boot the CF instead.
Overall Rating: 5 (1 ratings)
Correct Answer
Leo Laohoo Wed, 05/09/2012 - 15:12
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
mshatkus1 Wed, 05/09/2012 - 15:18
I don't have a compact flash card.  This switch isn't in production so it's not a monster deal to get it done "fast".  I need to get it done fast because I can't go home until its fixed .  So if the 2nd sup is in ROMmon can I just console into that sup (after pulling the active) and tell it to boot said image?  If this is a possible solution is there are link on Cisco's site you can post to give me step by step directions.  Thanks
mshatkus1 Wed, 05/09/2012 - 15:36
I got it.  Was in ROMmon.  I appreciate your help
Leo Laohoo Wed, 05/09/2012 - 16:32
  • Hall of Fame,
    2017 LAN, Wireless
Depends.  Not wanting to waste your time so you can go home, yes you can.
Recover a Supervisor Engine 720 from a Missing/Corrupted Cisco IOS Image or ROMmon Mode
I'm more concerned about WHY the supervisor card went into ROMmon.
mshatkus1 Wed, 05/09/2012 - 16:37
I forgot to copy the new image from the active supervisor to the standby before I changed the bootv and then reloaded the switch.  The standby sup didn't have the image loaded on it that the active sup had
Related Content
