Warning message
Using IP Communicator on Zero Clients
Jaime Valencia Wed, 05/09/2012 - 17:54
  • Cisco Employee,
  • Hall of Fame,
    2011
IPC is NOT supported for HVDs.
Even with Cisco 21XX/22XX clients you are limited to deskphone control.
Only the 6215 and VXC 4000 can be used for softphone control and get the rtp directly to the endpoint.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Related Content
