UCCX 8.5 Real Time Data vs Historical Data
Answered Question
May 9th, 2012
hi guys,
does anyone know how soon does the real time data gets written to the historical data/tables?
i have a customer who is trying to compare a real time stats at the end of the day and comparing it with historical report and found some missing stats.
so i was wondering if the mismatch is caused by the timer of how soon real time data gets written to the historical data/tables.
any pointers would be much appreciated.
kind regards
daniel
Correct Answer by anchoudh about 4 years 11 months ago
Hi Daniel,
Yes, your understaning it corect.
Call records (CCDR, CRDR, CQDR)) are written after each call is completed.
Hope it helps, please rate the helpful posts by clicking on the stars below the right answers !!
Anand
Overall Rating: 5 (1 ratings)
anchoudh Wed, 05/09/2012 - 19:35
  • Red, 2250 points or more
Hi Daniel,
Q.After a record contains data, is stored in memory, and is ready to be written to the Cisco Unified CCX database, when is it written to the database?
A.Call records (CCDR, CRDR, CQDR)) are written after each call is completed. Agent state records (ASDR) are written after agents change state. Agent connection records (ACDR) are written when an agent leaves Work state or after the call completes (if the agent does not go to Work state).
Note: CCDRs are written after the agent leaves Work state, when applicable. Otherwise they are written after the call ends.
Also please refer the "Chapter-3 Writing Database Records" in the below link for more details on this.
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_8_5/programming/guide/uccx85hradm.pdf
Hope it helps.
Anand
Please rate helpful posts by clicking on the stars below the right answers !!
Daniel Hardjopranoto Thu, 05/10/2012 - 01:48
Hi anand
Thanks for the response. Basically you are saying that there's no delay in terms of when the data gets written into the historical tables.
In other words, as soon as the call ends that particular call data is immediately available for retrieval from the ccx historical reporting client.
Is this correct?
Kind regards - Daniel
Correct Answer
anchoudh Thu, 05/10/2012 - 01:56
Hi Daniel,
Anand
Related Content
