Lms4.2 not able to collect config or inventory from WS-SVC-WISM2-K9
stighollund
We have just installed lms 4.2 and are having problems collecting config and inventory from ws-svc-wism2-k9.  The response from TAC was that this is not supported.  And it also says this in
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.2/device_support/table/lms42sdt.html
Is this really the case ?  Will there be released packeges to support this.  It would be really helpful for us if this was supported in lms4.2.
Vinod Arya
Yes WISM2 is not supported in LMS currently and no plan for this in LMS 4.2.1 as well. You may want to check it with wireless experts if there is infrastructure softwares like WCS which can manage WISM modules.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
WCS has been superseded by Cisco Prime NCS.  NCS can manage WiSM-1/WiSM-2.
Thank you very much for your reply.  We will use NCS to manage Wism instead.
