Warning message
Cisco 1841 + Ip public + routing
May 9th, 2012
Hello Everyone,.
Recently i've ordered some new IP public from my ISP. I have to assign one of these to one of my server. Am not pro in cisco routers and just occasionally do some small not serious manipulation in the router. When i check the config file of the router. I can see ip route set for the older public ip address that i have.  I try to do the same with one of the new ip address but it does not work. What am i missing?
Trying 196.192.11.172...
Connected to 196.192.11.172 (196.192.11.172).
Escape character is '^]'.
User Access Verification
Password:
CISCO>en
Password:
CISCO#sh run
Building configuration...
Current configuration : 1930 bytes
version 12.4
service password-encryption
hostname CISCO
boot-start-marker
boot-end-marker
logging buffered 5000 debugging
enable secret 5 $jfijaifjafdfhughfhdsakfhioaI1
enable password 7 00454765465448168746C
no aaa new-model
resource policy
ip cef
archive
log config
  hidekeys
controller DSL 0/0/0
mode atm
line-term cpe
line-mode 2-wire line-zero
dsl-mode shdsl symmetric annex A-B
line-rate auto
bridge irb
interface Loopback1
no ip address
interface FastEthernet0/0
ip address 196.192.11.172 255.255.255.248
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.11.1.9 255.255.255.0
ip nat inside
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
no snmp trap link-status
bridge-group 1
pvc 8/35
  encapsulation aal5snap
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
interface BVI1
ip address 192.168.5.216 255.255.255.252
ip nat outside
arp timeout 300
ip default-gateway 192.168.5.215
ip route 0.0.0.0 0.0.0.0 192.168.5.215
ip route 196.192.0.178 255.255.255.255 196.192.11.170
ip route 196.192.11.167 255.255.255.255 196.192.11.170
ip route 196.192.11.168 255.255.255.255 196.192.11.170
ip route 196.192.11.169 255.255.255.255 196.192.11.170
ip route 196.192.11.171.255.255.255.255 10.11.1.8
no ip http server
no ip http secure-server
ip nat inside source static 10.11.1.8 196.192.11.171
access-list 1 permit any
access-list 10 permit 10.11.1.0 0.0.0.255
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
login
line aux 0
line vty 0 4
password 1 jodjsoamdfsopafhdisf
login
rotary 50
scheduler allocate 20000 1000
end
ip route 196.192.0.178 255.255.255.255 196.192.11.170   <== This is the new ip. I did the same as below but does not work.
ps : natting is done on my shorewall (linux)
cclemmer Thu, 05/10/2012 - 00:55
What isn't working? Do you get an error message when trying to add the static route, or the route is added and you still don't have layer 3 connectivity to the new sever? How is the new server physically connected to your router?
yogeshakal Thu, 05/10/2012 - 01:18
No i don't get any error when adding the static route. I've got different zones in my network and this one is connected through my DMZ Switch. All the other servers given Ip public are all in the same zone.
cclemmer Thu, 05/10/2012 - 06:15
Does 196.192.11.170 know how to get to 196.192.0.178? If you are routing to that device out fa0/0 for the new server, have you verified that the next hop .170 has reachability?
