Manualy add a new vLan to blade server in Cisco UCS 5108
Answered Question
May 11th, 2012
I have tried to add a new vLan to my server chassie and then add it manulay to the blad server. The problem is that i can´t connect to the network, do I have to initate it in the fabric switch? Anyone got a tip where to start trubleshooting?
/T
Correct Answer by padramas about 4 years 9 months ago
You need to SSH into Fabric Interconnect ( FI ) and then change to nxos context
Padma
Overall Rating: 5 (1 ratings)
padramas Fri, 05/11/2012 - 09:46
Hello Tobias,
To start with,
1) Are you able to ping the gateway of the device ?
2) If not, we need to trace the MAC address. We can determine the path taken by vnic of server by following command
show service-profile circuit server x/y  ( where x is chassis number and y is blade slot number )
3) Connect to nxos mode of the FI and check whether mac address is learned on correct VLAN or not
show mac address-table
If not, we need to verify OS NIC VLAN configuration ( whether assigned proper VLAN or not )
4) Verify VLAN configuration on the upstream switch.
Padma
tobias1979 Fri, 05/11/2012 - 10:37
HI
Do I have to add the vLan under appliance to, it seams to be missing there?
padramas Fri, 05/11/2012 - 10:44
Hello Tobias,
Not required unless if you are trying to communicate to a device connected to FI on appliance port.
Providing more information about source / destination would help us here.
What is the OS installed on the blade ?
Chassis and blade number ?
Are you able to ping the gateway ip address for Vlan 102 ?
Padma
tobias1979 Fri, 05/11/2012 - 11:03
HI
The vLAn should be deployed to all blad servers 6 at the moment in 2 chassis. I ám running esxi 4.1 on the blade. I can´t ping the gateway from a vm on the blade.
Tobias
padramas Fri, 05/11/2012 - 11:37
Tobias,
Is the virtual machine NIC configured to use VLAN 102 in ESXi ?
Padma
rammuthaiya Fri, 05/11/2012 - 11:39
Hi ,
Make sure that, correct VLANs have been added to vNIC 0f the blades on whicj ESX is installed.
Ram
padramas Sat, 05/12/2012 - 00:49
On FI, check the mac address of the VM nic is learned on vlan 102 or not.
Padma
tobias1979 Sat, 05/12/2012 - 13:01
The vNIC in UCS has the same MAC adress as the vSwitch in vSphere. How can I see a specific virtual machines mac adress in USC´n?
padramas Sun, 05/13/2012 - 20:00
You can check the mac address table by
connect nxos
Padma
tobias1979 Sun, 05/13/2012 - 22:00
HI
How do I connect to "nxos", is it lika a terminal session to UCS?
.T
Correct Answer
padramas Sun, 05/13/2012 - 22:03
Padma
tobias1979 Tue, 05/15/2012 - 13:01
I found the MAC adress and we found the problem in the router. Thank you Padramas you have been very helpful.
Rgds
Tobias
Related Content
