Warning message
eigrp stub
May 11th, 2012
                   Can someone direct me to documenation of what the downside is of running stub. Especially if it was in an environment prior to the licensing changes and running full eigrp. What is the implication if it has more than one neighbor?
thx as always.
Giuseppe Larosa Fri, 05/11/2012 - 11:16
  • Hall of Fame,
    Founding Member
Hello Whanson,
the EIGRP stub router does not pass routes learned from one neighbor to another neighbor, so no EIGRP router can be downstream of it.
It is good for remote offices or in any case where there are no routers downstream on the leafs of your topology.
EIGRP stub is a feature that had been introduced as a way to control EIGRP Query propagation. Then in the licensing schema of multilayer switches Cisco started to deliver EIGRP stub only on lower feature set
Hope to help
Giuseppe
Related Content
