ANM Virtual Appliance - SCP, TFTP or SFTP Support
Answered Question
May 13th, 2012
Good day all,
I would just like to know if, as part of the back-up configuration supported on ANM 5.2, to back-up the ACE configurations, licenses, etc., and then have them copied to another system via SCP, SFTP or TFTP, is this supported to have these copied to ANM.
So my question is, does ANM Virtual Appliance have support/functionality for any of these services (TFTP, SFTP or SCP), or would this need to be a separate system? I do not think ANM supports this, but would just like confirmation one way or the other if possible please.
Thank you in advance.
Paul.
Correct Answer by Daniel Arrondo Ostiz about 5 years 1 month ago
Hi Paul,
If I understood you correctly, you want to copy the ACE backups to the ANM to store them there. That, I'm afraid, is not supported. You need to define an external server to store them.
Daniel
Overall Rating: 5 (1 ratings)
Correct Answer
Daniel Arrondo Ostiz Mon, 05/14/2012 - 03:54
  • Cisco Employee,
Hi Paul,
Daniel
Paul Pinto Tue, 05/15/2012 - 00:25
Hi Daniel,
Thank you for your respones and clarification. Any plans for this in the future?
Paul.
Daniel Arrondo Ostiz Tue, 05/15/2012 - 02:58
  • Cisco Employee,
Hi Paul,
ANM is supposed to be a management appliance, not a file storage server, so I don't think using it as backup repository will ever be supported.
Daniel
ppflaum12 Sat, 05/19/2012 - 07:55
This would be a good feature to add
Related Content
