Simultaneous Ring - voice hunt-group does not work
Answered Question
May 13th, 2012
Hello all,
I have the request for simultaneous ringing while using a CME v 7.0, however the following configuration doesnt work:
voice hunt-group 2 parallel
final 3201
list 3201,85201,5201
pilot 5201
What we want is when someone calls 5201 to ring simultaneously to 5201, 3201 and 85201.
Any suggestions?
Many thanks in advance
Correct Answer by Chris Deren about 4 years 11 months ago
What I am suggesting is that you cannot have hunt pilot and ephone-dn with the same DN as that creates a conflict and ephone-dn I believe will always be prioritized.  You need to either change the pilot DN to be something else or the ephon-dn to be something else.
Chris
Overall Rating: 4.5 (2 ratings)
Chris Deren Sun, 05/13/2012 - 12:17
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Your best option would be to configure shared line appearance on the phones with ephone-dn 5201. If you do require hunt group then the pilot cannot be shared with another ephone-dn, you have both 5201 defined as pilot and a member.
HTH,
Chris
Georgios Sotiro... Sun, 05/13/2012 - 13:45
Hello Chris, thanks for your reply
So what you suggest is to remove the dn 5201 from a member? For example,
final 3201
list 3201,85201
pilot 5201
ephone-dn  1
number 5201
label 5201
name George
description George
I think i have tried that already  and didnt work, is the above what you suggest to do?
Again thanks for your prompt response
Correct Answer
Chris Deren Sun, 05/13/2012 - 15:54
  • Hall of Fame,
Chris
Related Content
