I enable multicast on one of the MOH server in CUCM and added this server in Media resource group assigned this group to devicepool.
CME SRST Router configuration,
dial-peer voice 70 pots
description MoH
destination-pattern 7000
port 0/2/3
ephone-dn 70
number 7001
preference 9
moh ip 239.1.1.1 port 16384 route 10.255.222.253(router loopback Ip) out-call 7000
Voice port is comming to off-hook when i configured ephone-dn ,we are captured data cooming from voice port ,music is cooming from the port but it is not playing when user place call on hold.
RTR222#show ccm-manager mu
Current active multicast sessions : 1
Multicast RTP port Packets Call Codec Incoming
Address number in/out id Interface
239.1.1.1 16384 0/0 66440 g711ulaw Lo0
RTR222#sh ephone sum
hairpin_block:
Max 70, Registered 0, Unregistered 0, Deceased 0 High Water Mark 71, Sockets 0
ephone_send_packet process switched 0
Max Conferences 77 with 0 active (8 allowed)
Skinny Music On Hold Status - group 0
Active MOH clients 0 (max 1300), Media Clients 0, B-ACD Clients 0
File music-on-hold.au (not cached) type AU Media_Payload_G711Ulaw64k 160 bytes
MoH Live feed configured from DN 70
MoH Live feed: Good signal
Moh multicast 239.1.1.1 port 16384
File play position 345283 file type 3 current type 3
Play offset 21280, Write offset 53280,File start 24 end 496521
File buffer at 14D0485C, buffer size 64000
RTP ssrc 85EEB601 timestamp_offset 0 position 2588 reposition 0
Max process service interval 55983 (last 50616)
Min interval 20000, missed 0 run 0 (us)
moh_process_service counter 29563493
Max Media process interval 2903737029 (last 533731) run 0 (us)
File system max access time 4753 (us) (last 2911) with late-reads 0
0 clients interrupt service, 0 process level
0 no-conversion, 0 a-to-mu, 0 mu-to-a
0 packets serviced at interrupt, 0 at process
Live feed timer 2000 packets 17183 last RTP payload 0 size 160
Last signal 23704 timeout counter 0
Live Codec 4 File Codec 4
Live MoH connects 68, out-call attempts 30330
Media Client Tx: 0 Xcode Tx: 0
But it is playing flash music.
