Warning message
fax configuration on h.323 gateway
May 14th, 2012
            Hi I am facing a problem in making outgoing call from fax machine on h.323 gateway. I have FXS DID card installed in gateway. Fax machine is connected to FXS DID card ports.
The incoming fax is receiveing but I can not make outgoing from fax or would not be able to send fax.
When we do outgoing from Fax it show incomplete number dial can any one help me on this ...
I have created pots dial-peer for FXS/ DID port, i have created dial-peer for E1 card, the route patter with fax DN number is also created in CUCM.
The CUCM version 8.5.
Nizar Abuseni Mon, 05/14/2012 - 03:10
Can you show me the sh run of the voice gateway, also i will need the exact digits you dial from FAX.
regards,
Nizar
TTSL GSM Mon, 05/14/2012 - 03:15
Hi Nizar,
Please ignore the forum.
Thanks & Regards
Saravanan
