cryptomaps
Answered Question
May 14th, 2012
On my router is is possible to create multiple site to site tunnels to different destinations ? i gather you jsut create multiple cryptomaps and assign them to the outside interface ?
cheers
Correct Answer by olpeleri about 5 years 1 month ago
Too many tunnel interfaces? A Cisco router should be able to handle that. How many spokes are involved?
Design wise you can proceed via many ways:
A) HUB does not need to initiate connections:
1- Leverage a tunnel type mgre [ on the hub] aka DMVPN. Then we have 1 Multipoint tunnel interface.
2- Use DVTI [ spoke ] / DVTI  [ hub ] with EZVPN
3- Use VTI on spokes + DVTI on hub with a routing protocol
B) HUB need to initiate connections:
use Tunnel protection, one tunnel per spoke.
Overall Rating: 5 (2 ratings)
Punit Jethva Mon, 05/14/2012 - 03:50
I think crypto maps are an easy Method of configuring, if there will be no multicast traffic between the site which would require VTI.
olpeleri Mon, 05/14/2012 - 04:11
  • Cisco Employee,
Crypto maps are the old way of configuring VPN. It's always a source of problems when ACL are not symmetrically configured.
U should use tunnel protection [ ipec ipv4 or gre ip]. It's wat simplier to configure / maintain.
Olivier.
carl_townshend Mon, 05/14/2012 - 04:20
is also prefer the vti, they are easier and support multicast, routing protocols etc
Punit Jethva Mon, 05/14/2012 - 04:27
just wondering configuring site-to-site tunnels to different destinations, won't it create many tunnels on the router?
Correct Answer
olpeleri Mon, 05/14/2012 - 04:42
  • Cisco Employee,
Related Content
