Warning message
Active-Active firewall Admin context
May 14th, 2012
Hi all,
My problem statement was:
my box is ASA 5585x, since this model have G0/0 - 0/7 sufficient interface, so i no need to do sub-interface for the context.
My question:
a. is it cumpulsary must have the admin context on A-A deployment?
Somehow i read on http://www.techrepublic.com/blog/networking/understand-the-pros-and-cons-of-using-cisco-asa-multiple-context-mode/1413
it mention that "The Admin Context is not restricted and can be used as any other security context."
Can i just exclude this admin context?
b. Refer to my config snipet, can i just allocate management interface to the admin context, instead of allocate it to any inside/outside interface?
c. Is it a good practice not to use the same interface to do LAN failover and stateful failover? I facing the problem of "ghost image" when i enable the multiple mode and both LAN/stateful failover on same interface.
thanks
Noel
P.S: Config snipet
admin-context admin
context admin
  allocate-interface Management0/0
  config-url disk0:/admin.cfg
  join-failover-group 1
context public-internet
  allocate-interface GigabitEthernet0/0
  allocate-interface GigabitEthernet0/1
  config-url disk0:/public-intenet.cfg
  join-failover-group 2
context secure-voice
  allocate-interface GigabitEthernet0/2
  allocate-interface GigabitEthernet0/3
  allocate-interface GigabitEthernet0/4
  config-url disk0:/secure-voice.cfg
yong khang NG Mon, 05/14/2012 - 04:53
Hi Varun,
Thanks for reply.
Appearnatly my ASA 5585x box facing "ghost image" on the home screen, where it cannot display the real time traffic at the panel.
My concern come to split my previous LAN/State failover interface to seperate interface then, just hope it can solve the problem.
I am now using ASDM 6.47, according to cisco statement it's been solve on this issue, but it seems still happen on my case.
Any command can let me troubleshoot on this?
Noel
varrao Mon, 05/14/2012 - 04:56
  • Red, 2250 points or more
Can you share a screen shot of the issue that you are facing?
Varun Rao
Security Team,
Cisco TAC
yong khang NG Mon, 05/14/2012 - 05:03
few amendment
a. the ASDM now loading with ASDM-647.bin
b. please check the photo snapshot, i am pressing home tab but the image still stay at monitoring page. The experience somehow will make the whole ASDM client hang and need to restart it.
thanks
Noel
varrao Mon, 05/14/2012 - 05:44
I just checked about this bug, and it seems that this bug has now been fixed in the ASDM image 6.4.7.53, so you can upgrade the ASDM to this version to get past this bug.
Varun Rao
Security Team,
Cisco TAC
