Warning message
Syslog Server
Which Syslog server do you suggest for collecting syslog message in network ? on internet there are many and many syslog server and all of them claim their product is the best for all needs and in entreprise level.
So I had to create this discussion on some forums included Cisco Support in order get feedback from Network administrators in every level,small,medium and enterprise.
Thanks for any suggestion and recommandation.
Overall Rating: 3 (2 ratings)
caniculari Mon, 05/14/2012 - 06:21
At my experience in a small enviroment it's enough with the syslog daemon of UNIX or GNU/Linux. The main advantage is it's free and easy to configure. Could be hard to see the particular messages at the beginning, but with a little practice with the shell, it's very powerful like Cisco's CLI.
cflory Mon, 05/14/2012 - 07:21
  • Bronze, 100 points or more
I agree with Luis, and would prefer a UNIX derivative, but if you're looking for something that's GUI driven and that may need to run on Windows, Kiwi makes a good product:
http://www.kiwisyslog.com/
-Chris
HTH!
jamescox3 Mon, 05/14/2012 - 11:44
For the enterprise I really like Solarwinds Network Performance Monitor, AKA NPM. While the syslog is only one feature of the product it is easy to use and search since it's all web based. You can also set alerts on syslog events that can email you of problems.
Check out the other features that NPM has, very helpful reporting and alerting tools.
Related Content
