Warning message
CUBE to SIP PSTN & Keep-alives
                   When running CUBE on a 2900 ISR to connect to a SIP PSTN provider, is a keep-alive packet required by the gateway in order to keep an RTP connection open? If it is, then is this an online or offline respones that is required, and with what frequency?
Appreciate any help.
Many Thanks
Norman
Ayodeji Okanlawon Mon, 05/14/2012 - 08:55
  • Cisco Designated VIP,
    2017 IP Telephony
Norman,
Hi, No you dont need a keep alive to keep your rtp session open. Your session timers do that. Keep alives are only used via options ping to monitor the state of your sip trunks from a cucm perspective
Related Content
