BGP Not logging too Syslog Server
May 14th, 2012
I have an issue where my bgp logs are not being sent to a syslog server. I am getting %SYS-5-CONFIG_I: Configured from console by user on vty0 (x.x.x.x), so there is proof logging is working. Howerver, when I do a clear ip bgp A.B.C.D the following are generated and not sent to the syslog server.
May 14 18:35:32: %BGP-5-ADJCHANGE: neighbor x.x.x.x Down User reset
May 14 18:35:32: %BGP_SESSION-5-ADJCHANGE: neighbor 10.255.215.2 IPv4 Unicast topology base removed from session  User reset
May 14 18:35:40: %BGP-5-ADJCHANGE: neighbor x.x.x.x Up
Since these log messages are notifications, and my config is set for notifications, I would think all notifications would be sent to the syslog server. Am I missing something, in this regard, does BGP require something else to send syslogs?
Lines from router config:
service timestamps log datetime
logging buffered 50000 notifications
logging console notifications
logging history notifications
logging trap notifications
logging facility local5
logging source-interface Loopback0
logging x.x.x.x
snmp-server enable traps syslog
bgp log-neighbor-changes
Thanks in advance!
Bret
bret Mon, 05/14/2012 - 12:12
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited, 1 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level notifications, 155 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level notifications, 87 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
    Trap logging: level notifications, 54 message lines logged
        Logging to 208.238.173.202  (udp port 514, audit disabled,
              link up),
              54 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
        Logging Source-Interface:       VRF Name:
        Loopback0
Log Buffer (50000 bytes):
May 14 18:43:16: %SYS-5-CONFIG_I: Configured from console by bret on vty0 (x.x.x.x)
May 14 18:55:11: %SYS-5-CONFIG_I: Configured from console by bret on vty0 (x.x.x.x)
May 14 18:55:20: %BGP-5-ADJCHANGE: neighbor x.x.x.x Down User reset
May 14 18:55:20: %BGP_SESSION-5-ADJCHANGE: neighbor x.x.x.x IPv4 Unicast topology base removed from session  User reset
May 14 18:55:21: %BGP-5-ADJCHANGE: neighbor x.x.x.x Up
cadet alain Mon, 05/14/2012 - 12:54
are there any logs sent to the server?  have you got reachability to the server from this source ?
Regards.
Alain.
bret Mon, 05/14/2012 - 14:24
Yes I am getting logs to the syslog server.
I am able to get this log to the sysog server. %SYS-5-CONFIG_I: Configured from console by user on vty0 (x.x.x.x)
Related Content
