sawgupta Mon, 05/14/2012 - 20:30
  • Bronze, 100 points or more
Use the "session 1" command from ASA. It will open a IPS session. If this is the first time you are accessing IPS, it will open the setup wizard. Otherwise, you may simply issue "setup" command on IPS CLI.
In the setup wizard, you can configure the management IPS address.
http://www.cisco.com/en/US/docs/security/asa/asa84/asdm64/configuration_guide/modules_ips.html#wp1170445
Sawan Gupta
Related Content
