site to site tunnel between to WAN locations
May 14th, 2012
Dear friends.. i have couple of doubts regarding the VPN connectivity .. between my site and other WAN site ...
can some one please look at below and clear my doubts ..
1. i am given with a public IP from remote site which will be my peer address...
2. on My router i dont have any puclic IP .. i have a machine inside my network which is on private IP and i am natting this private IP onto public IP from router.
3. do i need a public IP on router also ... ?if es then .. shld i go for a loopback address ...? but then how to protect my router from attachks if i put this on public IP... i have a default route on my router which points to ISP router.
4. i am using CCP to configure the same ... and error i am getting is tunnel down and routing error also ..
5. what ACL i need to create ... i just need to allow RDP .. secondly the protected network will be my inside and his inside only .. correct me if i am wrong ..
Thanks for the time and help ..
SRC Ciscoo 1800 == WAN ==> DSTN Router ==> CHKPoint VPN device
JATINDER KUMAR Thu, 05/17/2012 - 04:05
Dear Rohan,
can you please provide me the answers for my above queries as i have to implement the same for one project .. thanks ... would surely go through the link
nikalleyne Thu, 05/17/2012 - 12:48
Hi Jatinder,
You don't need a public IP on your device for your site, your device is already being seen with a public IP as a result of the NAT.
You need to ensure you have the public IP for the other VPN site and give the personnel at the other end your Public IP within the NAT not the private.
The two devices should be able to detect if there is a NAT and reconfigure to use NAT traversal to setup the tunnel.
Are you getting any specific errors during the setup?
JATINDER KUMAR Fri, 05/18/2012 - 21:55
thanks for the reply .. yes i am getting multiple error .. first if about routing ... as i have default route... to my ISP .. do i need some other route....? i dont thnk so ... plz advise.. i am using CCP to configure the same and its asking for internal IP also to be protected .. so this will be their LAN ...
will post you the screen shot ASAP..
any comments plz add
Julio Carvajal Sat, 05/19/2012 - 00:21
  • Purple, 4500 points or more
Hello Jatinder,
You do not need any particular route, just the default one pointing to your default gateway.
I am going to try to respond all of your queries.
You need a public ip address on the internet router, you will perform a no_nat configuration for the communication between the two end networks.
Now if you only want to allow RDP via the L2L tunnel, you can specify that on the Crypto ACL ( Just match tcp port 3389)
If you want you can provide me the 2 internal networks on both sides an I can try to build an example for you!
Do rate all the helpful posts....
Julio
Cisco Security Engineer
JATINDER KUMAR Tue, 05/29/2012 - 12:39
Thanks for the reply.. sorry took loads of time to get back on this ...
ok first of all my internal networks ...
site A : 10.10.11.3/32 single machine to be access by second side
Site B : 172.17.24.169 which then is natted on device to another internal IP but i am asked to do the VPN on this.
i tried doing this and below is my config .. i thnk as suggest by you i missed few things ...
1. do i need to remove the NAT from 11.3 ip .. i thnk you mean yes...
2. i dont have a public IP on router becasue of security .. so if i configure one on loopback .. any best practices to protect the same frmo public attacks.
Thanks for the help ... this is pre share site to site tunnel .. one more things which got bit odd today. was.. when i configued this .. although i didnt fo "no nat" thing .. but dont know form where i got another ip next to pre-sharekey and after set-peer command ... which is not form my network neither i thnk from remote network ...
MIRROR CONFIG FROM ROUTER
crypto isakmp policy 1
authentication pre-share
encr aes 256
hash sha
group 2
lifetime 3600
exit
crypto isakmp key XXYYZZ@ address 172.30.7.194  [NOT MY ADDRESS FROM ANY SITE]
crypto ipsec transform-set CLIENT_Transformation ah-sha-hmac esp-sha-hmac esp-aes 256
mode tunnel
exit
ip access-list extended SDM_1
remark CCP_ACL Category=4
remark IPSec Rule
permit ip 172.17.24.169 0.0.0.0 10.10.11.3 0.0.0.0
exit
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Apply the crypto map on the peer router's interface having IP address that connects to this router.
set transform-set CLIENT_Transformation
set peer 172.30.7.194  [NOT MY ADDRESS FROM ANY SITE]
match address SDM_1
exit
i know i am missing smthing .. please advise .. is it no nat.. or there are other config mistakes also.. or its just public ip on router... and what is that IP in red above ...?
JATINDER KUMAR Tue, 05/29/2012 - 12:51
just type a lot and dont know where it gone .. very bad ...
thanks Julio for the reply ... now i have to type all again it was lot ..
no worries... ok first to answer your questions ..
Site A : 10.10.11.3/32
Site B : 172.17.24.169/32 this is then natted to some other priate ip but i am asked to configure vPn on this
secondly i dont have any public ip on my router all are configured on internal machiens and then on router which acts as a gateway is doing nat for the private IP and isp is routing our public IP. so no direct public ip and i dont want to give even .. but if this is a restriction then will give. that means the public ip of the router will act as the peer.. or the peer ip will still be the ip of internal machine .. dont  know .. becasue you were saying above that we have to perform no nat.. which actually i havent done .. so my 11.3 ip is getting natted to some public IP and i want to create tunnel between that specific mahcine only. so where will be my tunnel .. router to site be or internal machine to site b... plz advise..
and now the big confusion .. i did the config today .. and then when i did the mirror config just to see.. i saw some othe private ip .. below is my config .. ip nest to preshare.. and peer address is dont know from where it came,,, any idea whats that ...?
encr aes 256
hash sha
group 2
lifetime 3600
exit
crypto isakmp key  XXYYZZ#$%^@ address 172.30.7.194
crypto ipsec transform-set client_Transformation ah-sha-hmac esp-sha-hmac esp-aes 256
mode tunnel
exit
remark IPSec Rule
exit
set transform-set client_Transformation
match address SDM_1
exit
please advise .. what m missing .. thnk loads now .. "no nat" .. public ip on router and anyting else..
Julio Carvajal Tue, 05/29/2012 - 13:02
Hello Jatinder,
Sorry to hear that you have some issues trying to post this.
Ok first thing we are going to do a L2L so the tunnel will be between the devices behind both routers!
Yes, you will need to have a public ip address here as this will be the peer ip address configured on the other side!
The No_Nat configuration will look like this:
ip access-list e NAT
deny ip  host 10.10.11.3 host 172.17.24.169
permit ip any any
This is an ACL is being used for the NAT!
Hope this helps.
Rate all the posts that helps!
JATINDER KUMAR Tue, 05/29/2012 - 13:07
thanks julio for the quick reply.. though u guys already sleeping .. anyways the config which i posted above does this makes any sense..
and that means .. i configure the public ip on router and remove the nat which is there from 11.3 ip .. so my peer will become the wan interface/ip of router...
secondly can you pelase advise how can i protect the attacks as i know there will be loads of attacks once i give public ip on interface or in my case i will be giving it to loopback hope this will not be an issue...
what is the best practice to protect public ip on router...?
i am using ccp to config vpn .. anything frm you to add here
        any idea about the ip 172.30.7.194 which is coming in my config without me giving it .. what exactly is this
Julio Carvajal Tue, 05/29/2012 - 14:04
That 172.30.7.194 got to be a peer for a L2L connection!
To protect your Public IP on your router you can use different mechanisms :ACL, ,Control plane protection,Managment plane protection, uRPF,etc) There are so many ways you can protect to this attacks so do not worry for that.
First let's make the VPN tunnel to go up, then you can open another question on the security team and I would be more than glad to help.
JATINDER KUMAR Wed, 05/30/2012 - 00:54
thanks Julio.
sorry m asking the same question again .. do i need two public ips .. as when i am givng the peer ip on loopback and trying to connect ... i am getting some errors... on routing...
when i am doing the nat of internal machine to public ip ... then my tunnel fails .. really m not able to understand what m missing .. do i need to have publich ip on physical interface .. and my internal machine also .. or only on router... i followed this but no getting it ..
please advise.
http://www.routergeek.net/general/how-to-configure-site-to-site-vpn-in-cisco-routers/
my router is 861 .. vlan 1 ip .. 10.10.11.1 gateway for 10.10.11.3 which is my internal machine ...
i have one default route... which points to isp gatewat .. which is a private IP...
i am doing nat of 11.3 ip to public ip ..
please see the screen shot if this gives any idea
Ali Bahnam Wed, 05/30/2012 - 05:17
Good day,
As I understood that your Router that you configured the VPN on it isnot facing the internet and you have another device facing the internet and you did a static NAT on it to redirect the public IP tp you vpn router interface.
- why don't u configured NAT on your VPN router??
As I saw from the show run of your vpn router there is a missing config.
my advice is to configure NAT on this router then create Route MAP to exclude your internal traffic on the both sides.
Let me know if you have points that I didn't understand it.
JATINDER KUMAR Wed, 05/30/2012 - 12:11
hi Ali/ Julio .. spent almost full day but no success... not gettign the concept right .. please check the config attached and let me know what all mistakes m doing .. its getting failed on peer connectivity...
Current configuration : 6691 bytes
! Last configuration change at 20:55:01 UTC Sat Jan 7 2006 by admin
! NVRAM config last updated at 20:05:28 UTC Sat Jan 7 2006 by admin
version 15.0
no service pad
hostname EmtelTest
boot-start-marker
boot-end-marker
logging buffered 52000
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-3221256201
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3221256201
revocation-check none
rsakeypair TP-self-signed-3221256201
crypto pki certificate chain TP-self-signed-3221256201
certificate self-signed 01
  30820241 308201AA A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33323231 32353632 3031301E 170D3036 30313032 31323032
  35325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 32323132
  35363230 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100AE60 A8752492 A2E2B2D5 D9F8918D 4794A3C6 88FCF067 ABFEC1C8 F8F93F49
  05B1B5AC 0007C720 0FB6D2D6 5F4BCABA E58EFB27 5A6DF30A 2B105A7A 931DC596
  132DA42D EFA6EE1E E55256DB 6A06B499 83F96A67 72B56E00 013BA9B3 738EEE1B
  29B5BBB5 C412B9BC EBB53340 E5B8623F 0A3ED669 8FE816B8 597FE945 44E827D2
  4FC50203 010001A3 69306730 0F060355 1D130101 FF040530 030101FF 30140603
  551D1104 0D300B82 09456D74 656C5465 7374301F 0603551D 23041830 16801405
  182AE6DC 65F3A5E8 45106869 AED7F39A C64A5830 1D060355 1D0E0416 04140518
  2AE6DC65 F3A5E845 106869AE D7F39AC6 4A58300D 06092A86 4886F70D 01010405
  00038181 000902AC 08D682CA 91E707B5 343E8C8D 467DFAA7 D5F4FFC7 A1207346
DC5EED98 66045CF0 55EE1BD4 7F8B7B60 3CA514F2 76D3C9B9 5A87E412 2D86571C
  496E09A9 59F48533 6EBE23F1 E54D913F 205E2A2E 895A7675 A31114FA 8CECE920
  19FA3C7A 00989DCC 486A5E0A 1C376B0E 147878D4 7DD98C10 5F84C1DB 0C7D54EE
  EFB7430A D8
      quit
ip source-route
ip cef
ip name-server 196.192.81.61
ip name-server 196.192.81.62
license udi pid CISCO861-K9 sn FCZ1533C06Y
username username privilege 15 secret 5 password
encr aes 256
group 2
lifetime 3600
crypto isakmp key PSK-XXYYZZ address 1.2.3.4
crypto ipsec transform-set client_Transformation ah-sha-hmac esp-aes 256 esp-sha-hmac
description Tunnel to1.2.3.4
set peer 1.2.3.4
match address 100
interface Loopback0
ip address 196.192.80.6 255.255.255.248
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 172.30.7.194 255.255.255.252
ip access-group protect_inbound_traffic in
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
ip address 10.10.11.1 255.255.255.0
ip verify unicast reverse-path
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.30.7.193
ip access-list extended protect_inbound_traffic
remark IPSec Rule
permit ip host 172.17.24.169 host 10.10.11.3
permit udp host 1.2.3.4 host 172.30.7.194 eq non500-isakmp
permit udp host 1.2.3.4 host 172.30.7.194 eq isakmp
permit esp host 1.2.3.4 host 172.30.7.194
permit ahp host 1.2.3.4 host 172.30.7.194
permit icmp any host 196.192.80.6
permit ip host 1.2.3.4 host 196.192.80.6
deny   ip any host 196.192.80.6
access-list 10 remark CCP_ACL Category=16
access-list 10 permit any
access-list 100 remark CCP_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip host 10.10.11.3 host 172.17.24.169
control-plane
line con 0
logging synchronous
login local
no modem enable
line aux 0
line vty 0 4
exec-timeout 3 0
logging synchronous
login local
scheduler max-task-time 5000
end
Ali Bahnam Tue, 06/05/2012 - 06:45
Good day,
Please try to add this ACL  as shown below :-
access-list 110 deny ip host 10.10.11.3 host 172.17.24.169
access-list permit ip host 10.10.11.3 any
route-map test permit 10
match ip address 110
ip nat inside source route-map test interface FastEthernet4 overload
Please add the above to your router and update me.
JATINDER KUMAR Wed, 06/06/2012 - 09:08
i managed to do dat... the only thing which changed is to use loopback as a tunnel ip .. where in my physical interface ip was getting used so i gave a command to use loopback ip as my tunnel ip ...
now one thing .. i need to give internet to this machine .. m not sure if static nat of inside machine to a public ip will work .. please advise... and idea
JATINDER KUMAR Mon, 06/11/2012 - 23:12
hi ali .. requirement now is ..
1. on the tunnel my client connects to one server using RDP and they are able to do so .. but now on the same machine they have this web server configured and they want this web server to be accessed using public internet using some fqdn address/ public ip ...
2. dont know why but every morning the vppn tunnel stops functioning .. any idea why .. means client not able to connect to server ... from remote site.. any idea what i can check
Ali Bahnam Mon, 06/11/2012 - 23:44
regarding the vpn tunnel when the client unable to connect please apply this command to check the VPN status (sh cry isa sa) so if it Active then there is no problem on the VPN.
If it is not active try to ping the server on the remote site then try to connect also apply the above command.
Also apply the below to your router:-
crypto ipsec security-association lifetime seconds 86400
JATINDER KUMAR Mon, 06/11/2012 - 23:58
thanks alim .. but sh cry isa sa .. it shows active sessions .. but still clients not able to connect in mrng ...
secondly so lifetime tis already given ..do u thnk its something to do with MTU or idle time
Ali Bahnam Tue, 06/12/2012 - 02:24
I didn't see the liftime on your attached configuration, so please add it and test.
Are you mean that vpn down on the morning for a while then become up again (client have access)??
JATINDER KUMAR Tue, 06/12/2012 - 03:02
thanks ali for the time and reply...if you are talking about this life time .. then i am having below.
crypto isakmp policy 10
encr aes 256
group 2
lifetime 28800
two more things to share...
we were just troubleshooting the things .. and we found that on remote site device it shows tunnel up and they able to ping me .. but my site tunnel shows down ... and remote site is not able to RDP the server but able to ping.
secondly...i am getting this msg always
Jun 12 09:28:03.091: No peer struct to get peer description
Jun 12 09:28:03.171: No peer struct to get peer description
Jun 12 09:28:03.219: No peer struct to get peer description
Jun 12 09:28:03.255: No peer struct to get peer description
Jun 12 09:28:03.291: No peer struct to get peer description
Jun 12 09:28:03.295: No peer struct to get peer description
Jun 12 09:28:03.415: No peer struct to get peer description
what exactly is this ...
Ali Bahnam Tue, 06/12/2012 - 05:36
Please try to remove the below:-
ip access-group protect_inbound_traffic in  from the int fa 4
remark IPSec Rule
After you remove the above if it isnot work also , please post the configuration of the both ends routers.
JATINDER KUMAR Tue, 06/12/2012 - 05:50
thanks for the reply.. id otn know why my tunnel is not consistent ... very angry ...   cn you please advise one thing .. when applying acl for the tunnel what src and dstn ips will be .. will it be the private ips or the peer ips ...?
secondly can you please advise about my above error .. which i am getting ...
.. please check previous reply...
Ali Bahnam Tue, 06/12/2012 - 13:57
the  "No peer struct to get peer description" then that means that an access-list is not configured correctly.
on the ACL you must use the private IPs not the peers
So please use the private IPs on your ACL and update me.
Hope this will help you.......
JATINDER KUMAR Thu, 06/14/2012 - 04:27
i will surely update you ... now the tunnel is up .. i need one advice from you ... there is a public web site configured on the internal server  and now client wants this web site to be accessed via internel .. + he wants his VPN tunnel to be intact ../ please advice how can i have both the things for the same server for which tunnel is created.
About current VPN status it gets disconnected every mrng .. and dont know what it reconnects after couple of hours .. dont know why ... my side Cisco .. remove side non cisco (Checkpoint)
Related Content
