SSL offloading with .p7b file possibility?
Answered Question
May 15th, 2012
I am trying to install SSL certificates in ACE for my exchange servers in a serverfarm. I have recieved cert file from AD admin in .p7b format. I have not recieved any key file. Please clarify whether ACE supports SSL offloading with .p7b format.
The below thread suggests that .p12 file format is supported in ACE. But what about .p7b?
https://supportforums.cisco.com/thread/2032875
Madhan kumar G
Correct Answer by Daniel Arrondo Ostiz about 4 years 9 months ago
Hi Madhan,
The ACE doesn't natively support the PKCS7 format (.p7b), so, before importing the certificate, you will have to convert it into a different format.
The easiest way to do this is using OpenSSL (see www.openssl.org). The command to be used would be "
openssl pkcs7 -in .p7b -outform PEM -print_certs -out .txt". This will generate a text file including all the certificates in PEM format.
Also, please be aware that the PKCS7 format doesn't include the private key, so, you should have it in a separate file. This private key should be available in the device on which you generated the CRL.
I hope this helps
Daniel
Overall Rating: 5 (1 ratings)
Correct Answer
Daniel Arrondo Ostiz Tue, 05/15/2012 - 03:20
Hi Madhan,
I hope this helps
Daniel
Related Content
