CUCME Attempted Registrations
May 15th, 2012
I have an issue with my 3945 CUCME Router, with 8 VG224 Analog Gateways
The router  throw me a console message that says:
Memory full, run clear telephony-service ephone-attempted-registrations to refresh the storage
When I enter the show ephone attempted-registrations I got the following.
VASCMXGWY#sh ephone attempted-registrations
Attempting Mac address:
Num    Mac Address         DateTime                          DeviceType
1            10:30:46 Mexico Tue May 15 2012      Unknown 83
2            10:30:51 Mexico Tue May 15 2012      Unknown 83
3            10:30:54 Mexico Tue May 15 2012      SCCP Gateway (AN)
4            10:30:56 Mexico Tue May 15 2012      Unknown 83
And continues ..so I think that the buffer got full .
I need help to identify the cause of this problem when I check the registration status of my VG224 all seems fine and registered.
Thanks.
paolo bevilacqua Tue, 05/15/2012 - 08:49
  • Hall of Fame,
    Founding Member
If you enable debug tftp event, you should see the mac address of the device that is attempting to register.
You can also enable auto-registration to prevent the problem and indentify the device.
jesus.lazcano Tue, 05/15/2012 - 08:54
Hi Paolo,
Thanks for your response.
I have this output in the debug command
VASCMXGWY#
May 15 15:51:11.703: TFTP: Looking for VASCMXVG2.cnf.xml
VASCMXGWY#
May 15 15:51:13.071: TFTP: Looking for SKIGWEF489F2DE4.cnf.xml
May 15 15:51:13.071: TFTP: Looking for SKIGW00F13769B5.cnf.xml
May 15 15:51:13.071: TFTP: Looking for SKIGWEF489F2268.cnf.xml
May 15 15:51:13.071: TFTP: Looking for SKIGW00F137628F.cnf.xml
May 15 15:51:13.419: TFTP: Looking for VASCMXVG8.cnf.xml
VASCMXGWY#
May 15 15:51:14.227: TFTP: Looking for SKIGWEF489F09CC.cnf.xml
May 15 15:51:14.227: TFTP: Looking for SKIGWEF489F2E8E.cnf.xml
VASCMXGWY#
May 15 15:51:15.595: TFTP: Looking for SKIGWEF489F2F1A.cnf.xml
VASCMXGWY#
VASCMXGWY#
VASCMXGWY#
May 15 15:51:26.875: TFTP: Looking for VASCMXVG1.cnf.xml
VASCMXGWY#
May 15 15:51:31.871: TFTP: Looking for VASCMXVG5.cnf.xml
VASCMXGWY#
May 15 15:51:41.395: TFTP: Looking for VASCMXVG3.cnf.xml
VASCMXGWY#
May 15 15:51:49.303: TFTP: Looking for VASCMXVG4.cnf.xml
VASCMXGWY#
May 15 15:51:53.663: TFTP: Looking for VASCMXVG6.cnf.xml
VASCMXGWY#
VASCMXGWY#
May 15 15:52:13.127: TFTP: Looking for SKIGWEF489F2268.cnf.xml
May 15 15:52:13.127: TFTP: Looking for SKIGW00F137628F.cnf.xml
May 15 15:52:13.127: TFTP: Looking for SKIGWEF489F2DE4.cnf.xml
May 15 15:52:13.127: TFTP: Looking for SKIGW00F13769B5.cnf.xml
VASCMXGWY#
May 15 15:52:14.231: TFTP: Looking for SKIGWEF489F09CC.cnf.xml
May 15 15:52:14.231: TFTP: Looking for SKIGWEF489F2E8E.cnf.xml
VASCMXGWY#
May 15 15:52:15.595: TFTP: Looking for SKIGWEF489F2F1A.cnf.xml
VASCMXGWY#
I Have a question, Why is this happening if I see all the VG224 ports registered in CUCME
Im a using SCCP STCAPP
paolo bevilacqua Tue, 05/15/2012 - 21:30
  • Hall of Fame,
    Founding Member
They have some "ccm config" commands left, remove them.
Related Content
