UCS with UCCX 8.5
Answered Question
May 15th, 2012
Hello I need help!
What are the recommendation to install CCX-85 over UCS-CS210M2-VCD2.
can anyone help me?
Best Regards.
Correct Answer by Chris Deren about 5 years 3 months ago
Can you eleborate your on your question? What exactly are you looking for?
CCX 8.5 is supported on this hardware with 3 different deployment sizes (OVA files) 100, 300 and 400 as documented here:
http://docwiki.cisco.com/wiki/Virtualization_for_Unified_CCX
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Downloads_%28including_OVA/OVF_Templates%29#Cisco_Unified_Contact_Center_Express
HTH,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Tue, 05/15/2012 - 13:45
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
Related Content
