Warning message
Sip calls issue via H323
May 15th, 2012
I have the follow environment:
ip phones (SCCP and SIP) ----------- CME-SRST(Site B) --------H323-----------CUCM (Site A)
                                                   PSTN
Every phones are registered on CUCM (site A) in SRST mode.
The SCCP phone are doing outbound call normally via PSTN local, but the SIP phones calls are dropping.
thanks.
Gregory Garrian Tue, 05/15/2012 - 13:55
  • Cisco Employee,
Are you saying that this problem happens only in SRST mode?
Can you post the configuration for the Site B CME-SRST?
Jean Lofrano Wed, 05/16/2012 - 05:41
Yes, befored SRST configuration the environment was working with SIP phones registered on CME.
I have in the site A SIP phones (registered on CUCM) and it can to do outbound call via site B PSTN normally.
My problem is only with SIP phones of the site B that are registered on CUCM (site A).
The run file was attached.
Gregory Garrian Wed, 05/16/2012 - 07:26
  • Cisco Employee,
Again, just to clarify:
Originally, you had two sites, A with CUCM and B with CUCME.  Both sites have SCCP and SIP phones registered to their local CUCM/CUCME.
Now, you've configured the Site B CUCME router for SRST and the Site B phones (SCCP and SIP) are registering to the CUCM at Site A.
In this new scenario, all site A phones (SCCP and SIP) can make outbound calls to the PSTN at Site B fine.  Also, the SCCP phones at Site B can make outbound calls to the PSTN.
The problem is with the SIP phones at Site B, which are registered to the CUCM at Site A.  They can not make outbound calls to the PSTN.
Is this correct?
If so, based on your last attached debug, I'm suspecting a codec issue.  Are your media resourses and MRGL configured properly?
Jean Lofrano Wed, 05/16/2012 - 08:03
Correct! Gregory.
I need to create a Xcoder between CUCM and CME-SRST?
I didn´t any configuration with MRGL after srst configuration.
My SRST-CME (172.23.0.1) router has:
dspfarm profile 2 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729r8
codec g729br8
maximum sessions 2
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
it7-rot-df-01#  sh sccp
SCCP Admin State: UP
Gateway Local Interface: Vlan1
        IPv4 Address: 172.23.0.1
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 172.23.0.1, Port Number: 2000
                Priority: N/A, Version: 7.0, Identifier: 10
                Trustpoint: N/A
Transcoding Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 172.23.0.1, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 2
Reported Max Streams: 4, Reported Max OOS Streams: 0
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
Conferencing Oper State: ACTIVE - Cause Code: NONE
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 8, Reported Max OOS Streams: 0
thanks.
Gregory Garrian Wed, 05/16/2012 - 08:47
  • Cisco Employee,
It depends.  Since you have two sites, CUCM may have the devices is different regions. All of the SIP configuration on the CME doesn't come into play if the phones are registering to CUCM.
Look at your media resources in CUCM to see if they're registering correctly.  Check your region settings, specifically what codecs are being used between regions.  Also, check to see how the SIP phones are configured compared to a working SCCP phone from Site B.  For instance, do they share the same DP, CSS, etc.
Jean Lofrano Wed, 05/16/2012 - 10:11
I have the devices in different regions, device pool, PT and CSS...
I´m using codec default g711 between the sites and the media resources are configured normally and registered.
The gateway configuration is with site A device pool and CSS.
To change de device pool and css of the gateway config is a good test?
Gregory Garrian Wed, 05/16/2012 - 10:14
  • Cisco Employee,
Before you do that, check to see how the SIP phones are configured compared to a working SCCP phone from Site B.  For instance, do they share the same DP, CSS, etc.
Gregory Garrian Wed, 05/16/2012 - 10:17
  • Cisco Employee,
By that do you mean that at Site B you have a SIP and an SCCP phone, both with identical PT, CSS, DP, etc.?
And, with that identical setup, only the SIP phones are having problems?
Jean Lofrano Wed, 05/16/2012 - 10:20
Yes, correct. The site B have SIP and SCCP phones and both are with the same PT, CSS, DP... But only sip phones are having problem.
Jean Lofrano Wed, 05/16/2012 - 10:18
I did a test now and "sh voice call status" show the call, but it is dropped.
it7-rot-df-01#sh voice call status
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    MLPP Dia        l-peers
0x1C224    33FB 0x312EFB90 0/1/2            0/1:1  *084934444  None     0/104
Gregory Garrian Wed, 05/16/2012 - 10:27
  • Cisco Employee,
Can the SIP phones at Site B make calls to internal extensions?  Can they recieve calls from outside the network?
Jean Lofrano Wed, 05/16/2012 - 10:32
Yes. The sip phones at site B make calls to internal extensions.
My router is configured with "connection plar" forwarding the call for SCCP phone. It is working properly.
Jean Lofrano Wed, 05/16/2012 - 10:38
Gregory,
The SIP phones directory number does not have a dial-peer how we can to see bellow.
I´m going to create a dial-peer voip for them. What do you think?
it7-rot-df-01#sh dial-peer voice summary
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT    KEEPALIVE
100    voip  up   up             70[0-4].$          0  syst ipv4:172.20.1.106
101    voip  up   up             70[7-9].$          0  syst ipv4:172.20.1.106
102    pots  up   up             0[2-5].......$     0                      up   trunkgroup FXO
103    voip  up   up             0041........       0  syst ipv4:192.168.10.3
104    pots  up   up             0[6-9].......$     0                      up   trunkgroup FXO
105    voip  up   up             705.$              0  syst ipv4:172.22.0.1
106    pots  up   up             00[1-3]T           0                      up   trunkgroup FXO
107    pots  up   up             004[2-9]T          0                      up   trunkgroup FXO
108    pots  up   up             00[5-9]T           0                      up   trunkgroup FXO
109    pots  up   up             010T               0                      up   trunkgroup FXO
110    pots  up   up             01[1-9].           0                      up   trunkgroup FXO
111    pots  up   up             010[1-9]..         0                      up   trunkgroup FXO
             AD                                    PRE PASS                OUT
20001  pots  up   up             7060$              0                           50/0/1
20002  pots  up   up             7061$              0                           50/0/2
20003  pots  up   up             9000$              0                           50/0/20
20004  pots  up   up             9000$              0                           50/0/21
20005  pots  up   up             9000$              0                           50/0/22
20006  pots  up   up             9000$              0                           50/0/23
20007  pots  up   up             9000$              0                           50/0/24
20008  pots  up   up             7065$              0                           50/0/25
7060   voip  up   up             7060               0  syst ipv4:172.20.1.106
Jean Lofrano Wed, 05/16/2012 - 11:00
Hi Gragory!!!
The SIP phones are making outbound calls now!!!
The dial-peer voip was the solution.
thanks.
Jean Lofrano Wed, 05/16/2012 - 11:18
I put the follow:
dial-peer voice 706 voip
corlist outgoing DF
description LIGAR-CURITIBA-1
destination-pattern 706.$
session target ipv4:172.20.1.106
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
At the moment of the call o codec is being negotiated right now.
thanks.
Gregory Garrian Wed, 05/16/2012 - 11:11
  • Cisco Employee,
You wouldn't need any dial peers for the directory numbers on the SIP phones.
It doesn't look like you have an MTP setup on the gateway (CME).
On the gateway configuration for the CME router in CUCM do you have the "Require MTP" box checked off?
You may need to create the MTP on the gateway and register it to CUCM for it to work.
Related Content
