Cisco Jabber Licensing for iPhone and Android
Answered Question
Feb 23rd, 2012
Hi All,
I am a bit confused on the following:
1- Do I need to purchase any addtional licenses for Cisco Jabber (iPhone/Android) as the app is free in both market?
2- What is the difference between Cisco Jabber for iPhone and Cisco Mobile 8.1
Correct Answer by Jonathan Schulenberg about 5 years 5 months ago
  1. Yes you need to purchase a right to use license. The ordering guide (partners only) explains the details.
    1. If you are on UCL or UWL-Standard then the top-level SKU is MOBILE-K9.
    2. If you are on UWL-Professional then you already have the RTU license as it's included in the pro seat.
  2. Cisco Jabber has replaced the Cisco Mobile app. This was primarily a marketing decision.
Overall Rating: 5 (2 ratings)
Correct Answer
Jonathan Schulenberg Thu, 02/23/2012 - 03:51
  • Cisco Designated VIP,
    2017 IP Telephony
