Warning message
Cisco Jabber registration fails.
Answered Question
Jul 15th, 2011
Hi, I have a problem with Cisco Jabber application on Android.It fails to registrate to CCM.
CCM version is 8.5, Cisco Jabber is 8.6.1, I followed documentation
http://www.cisco.com/en/US/docs/voice_ip_comm/cumc/cisco_jabber/Android/86/Cisco_Jabber_Android_8.6.x_Admin_Guide.html#wp810478
And everything seems right. DNS is working, I can reach CCM web portal on phone web browser.
Do you have some tips how to troubleshoot, for example which logs is RTMT would be useful, or if there are any logs on Jabber.
Any help would be appreciated
Correct Answer by abraham1982 about 5 years 11 months ago
I changed the CUCM hostname under System->Server-> to the IP Address of the CUCM and now the Jabber client is registered and getting the DN. But I am unable to make or receive calls.
Any Help.
Abraham
Overall Rating: 5 (1 ratings)
bvanturn Fri, 07/15/2011 - 03:36
  • Cisco Employee,
Hi Jan,
I would start with a sniffer capture on CUCM so you can see the sip traffic. If you feel like you can also check the CallManager logs.
Correct Answer
abraham1982 Fri, 09/16/2011 - 03:42
Any Help.
Abraham
JohnPeca18 Wed, 09/21/2011 - 07:16
Hi, thank you very much, after months of failures, this advise helped. We changed CUCM hostname to IP address and Jabber registered. We are also able to make and receive calls.
abraham1982 Thu, 09/22/2011 - 09:52
Is your jabber client working as a primary device or an adjunct one which is associated to a deskphone and acting like a shared line.
Can you list the steps you took to craete this. if you dont mind
Abraham
abraham1982 Wed, 10/05/2011 - 01:52
I got it... the Jabber client works fine on a Samsung Galaxy
