jabber secure connect is not working
Feb 7th, 2012
I set up Anyconnect on ASA5520 and  enabled secure connect in CUCM.
I did everything as written in jabber for android administration guide and end user guide.
But when secure connect configured on my mobile, secure connect entry never created even though I entered all correct parameters such as gateway address, authentication group, username and password.
ASA log says:
SVC message: 16/NOTICE: The user has requested to disconnect the connection.
SVC closing connection: User Requested.
WebVPN session terminated: User Requested.
I succeeded in connecting via Anyconnect app on iPhone.
So I believe Anyconnect Vpn connection has no problem. License checked.
Anybody succeeded in implementing secure connect using AAA authentication?
Md Hasan Fri, 02/17/2012 - 14:07
  • Cisco Employee,
To isolate the issue, please check if Jabber works without ASA from inside using Wi-fi. If it does work, may be benefitial to re-post this question on the AAA /VPN/firewall side of the forum..
Ruud van Strijp Thu, 05/31/2012 - 08:00
I have the same issue; I fill in all the settings in Jabber, but after the wizard finishes, no connections show. Jabber does work on our internal WiFi, as well as through AnyConnect VPN on my Android phone. So the issue really seems to lay in my Jabber for Android.
Any thoughts?
