Dial format from tandberg C20 to Polycom
Magnus Ohm Tue, 05/15/2012 - 22:20
  • Cisco Employee,
Did you try setting the C20 call setup mode to direct and only call the public ip of the polycom unit?
/Magnus
Jens Didriksen Tue, 05/15/2012 - 22:51
  • Blue, 1500 points or more
In addition to Magnus' comment; if your C-system has an earlier firmware version than TC4.2, then it cannot do URI dialling unless it's registered to a GK, VCS etc as h.323cs was not supported in earlier software releases.
Also note the PLCM system has to be registered to a GK or similar to be able to receive URI type of calls.
Older PLCM systems also does not support Annex O URI dialling, which is the standard, and this is the only type of URI dialling which is supported by C-series.
Annex O: [email protected] or you can also use [email protected]_IP_address.
IP_address##Alias is PLCM proprietary "URI dialling" and will not work from a C-series.
You can, if you're using a VCS-C/VCS-E set-up, allow PLCM systems to call you using IP_address##Alias by doing a presearch transform on the VCS-E which transforms this address to Annex O type address.
/jens
