IP SLA for multiple host
Answered Question
May 15th, 2012
I have a problem
On my router I have configured Cisco EEM, which do next
event manager applet BGP_ISP_DOWN
event track 1 state down
action 1.0 cli command "enable"
action 1.1 cli command "conf t"
action 1.2 cli command "no ip prefix-list own-prefix seq 10 permit 10.10.10.0/24"
action 1.3 cli command "ip prefix-list own-prefix-bee seq 15 permit 10.10.10.0/24"
action 1.4 syslog msg "BGP peer ISP down 10.10.10.0/24 now through ISP2"
and this simple SLA
ip sla 1
icmp-echo 11.11.11.11 source-interface GigabitEthernet0/1.202
timeout 15000
frequency 15
ip sla schedule 1 life forever start-time now
Sometimes host 11.11.11.11 which outside for me, stops responding ICMP(for some reason), but my ISP have a host 11.11.11.12 which UP and respondinng ICMP.
Is there any way ping both hosts 11.11.11.11&11.11.11.12 in one sla?
Or have two sla's in some group?
thanks
Correct Answer by cadet alain about 5 years 2 months ago
If you need both hosts down for the tracked object to be down then you need a boolean OR because if you take the truth table for AND it is:
1 and 1 = 1
1 and 0 = 0
0 and 1 = 0
0 and 0 = 0
But the OR is:
1 or 1 = 1
1 or 0 = 1
0 or 1 = 1
0 or 0 = 0
Concerning the syntax it is not the same depending upon IOS version and so surely in yours it should be:
track 1 ip  sla 1 reachability
Regards.
Alain
Correct Answer by rizwanr74 about 5 years 2 months ago
Hi Cadet,
I believe the boolean retun has to be an "and" because of the problem the client is facing that IP-SLA decision is based on just one single return, therefore the boolean has to be an "and".
I hope that you would agree with me.
thanks
Rizwan Rafeek
yes you can use a boolean track with a OR like this:
ip sla 1
timeout 15000
frequency 15
ip sla 2
icmp-echo 11.11.11.12 source-interface GigabitEthernet0/1.202
timeout 15000
frequency 15
ip sla schedule 2 life forever start-time now
track 1 rtr 1
track 2 rtr 2
track 2  list boolean or
object 1
object 2
event track 3 state down
Regards.
Alain
Overall Rating: 5 (4 ratings)
rizwanr74 Wed, 05/16/2012 - 00:28
  • Gold, 750 points or more
Here is an example of tracking two IP-SLA(s) with tracking in boolean "and" otherwise "or" return.
track 2 ip sla 2 reachability
Router(config)# track 12 list boolean and
Router(config-track)# object 1
Router(config-track)# object 2
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_eot.html
Hope that helps.
thanks
Rizwan Rafeek
Krasnoperov Wed, 05/16/2012 - 01:49
seems I dont have track 1 rtr command
Might be you know why?
r1(config)#track 1 ?
  interface    Select an interface to track
  ip           IP protocol
  list         Group objects in a list
  stub-object  Stub tracking object
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.2(1)T1, RELEASE SOFTWARE (fc1)
Correct Answer
cadet alain Wed, 05/16/2012 - 03:44
  • Purple, 4500 points or more
1 and 1 = 1
1 and 0 = 0
0 and 1 = 0
0 and 0 = 0
But the OR is:
1 or 1 = 1
1 or 0 = 1
0 or 1 = 1
0 or 0 = 0
Regards.
Alain
Krasnoperov Thu, 05/17/2012 - 01:15
You was right
Multiple objects can also be tracked by means of a list, using a  flexible method for combining objects with Boolean logic. This  functionality includes:
Boolean AND function—When  a tracked list has been assigned a Boolean AND function, each object  defined within a subset must be in an up state, so that the tracked  object can also be in the up state.
Boolean OR function—When  the tracked list has been assigned a Boolean OR function, it means that  at least one object defined within a subset must also be in an up  state, so that the tracked object can also be in the up state.
Correct Answer
rizwanr74 Wed, 05/16/2012 - 00:36
Hi Cadet,
thanks
Rizwan Rafeek
cadet alain Wed, 05/16/2012 - 00:55
I think it should be an OR if he wants the tracked  object to be down if both pings fail but not if one only fails.
Tell me what you think about it.
Regards.
Alain
Krasnoperov Wed, 05/16/2012 - 01:42
Thanks, but in my track I need to check that all tracking hosts are down
Correct Answer
cadet alain Wed, 05/16/2012 - 00:13
ip sla 1
timeout 15000
frequency 15
ip sla 2
timeout 15000
frequency 15
track 1 rtr 1
track 2 rtr 2
object 1
object 2
Regards.
Alain
  ip           IP protocol
