OID changed WAAS firmware 4.4.5 ?
May 16th, 2012
I've posted this message also on TWACK.com.
We have upgraded our WAAS units from version 4.4.3c to 4.4.5. The problem that we now have is that the inline interfaces are not visible anymore in Orion. I've updated the MIB.cfg (that's the MIB database for Orion). When I do a MIB walk, and compare the results with both versions, and you can see that they are missing:
version 4.4.3c:
MIB,OID,Name,Value
MIB2-DAN-MIB-ADMIN,1.3.6.1.2.1.1.1.0,sysDescr.0,"Cisco Wide Area Application Services Software Hardware Version: oe574-4.4.3c.9 Cisco Wide Area Application Services (accelerator-k9) Software Release 4.4.3c (build b9 Nov 29 2011)  "
MIB2-DAN-MIB-ADMIN,1.3.6.1.2.1.1.2.0,sysObjectID.0,1.3.6.1.4.1.9.1.985
MIB2-DAN-MIB-ADMIN,1.3.6.1.2.1.1.3.0,sysUpTime.0,130212500
MIB2-DAN-MIB-ADMIN,1.3.6.1.2.1.1.4.0,sysContact.0,""
MIB2-DAN-MIB-ADMIN,1.3.6.1.2.1.1.5.0,sysName.0,
MIB2-DAN-MIB-ADMIN,1.3.6.1.2.1.1.6.0,sysLocation.0,
MIB2-DAN-MIB-ADMIN,1.3.6.1.2.1.1.7.0,sysServices.0,72
IF-MIB,1.3.6.1.2.1.2.1.0,ifNumber.0,7
IF-MIB,1.3.6.1.2.1.2.2.1.1.1,ifIndex.1,1
IF-MIB,1.3.6.1.2.1.2.2.1.1.2,ifIndex.2,2
IF-MIB,1.3.6.1.2.1.2.2.1.1.3,ifIndex.3,3
IF-MIB,1.3.6.1.2.1.2.2.1.1.4,ifIndex.4,4
IF-MIB,1.3.6.1.2.1.2.2.1.1.5,ifIndex.5,5
IF-MIB,1.3.6.1.2.1.2.2.1.1.6,ifIndex.6,6
IF-MIB,1.3.6.1.2.1.2.2.1.1.13,ifIndex.13,13
IF-MIB,1.3.6.1.2.1.2.2.1.2.1,ifDescr.1,"GigabitEthernet 1/0"
IF-MIB,1.3.6.1.2.1.2.2.1.2.2,ifDescr.2,"GigabitEthernet 2/0"
IF-MIB,1.3.6.1.2.1.2.2.1.2.3,ifDescr.3,"InlinePort 1/1/wan"
IF-MIB,1.3.6.1.2.1.2.2.1.2.4,ifDescr.4,"InlinePort 1/1/lan"
IF-MIB,1.3.6.1.2.1.2.2.1.2.5,ifDescr.5,"InlinePort 1/0/wan"
IF-MIB,1.3.6.1.2.1.2.2.1.2.6,ifDescr.6,"InlinePort 1/0/lan"
IF-MIB,1.3.6.1.2.1.2.2.1.2.13,ifDescr.13,Loopback
Version 4.4.5:
MIB,OID,Name,Value
MIB2-DAN-MIB-ADMIN,1.3.6.1.2.1.1.1.0,sysDescr.0,"Cisco Wide Area Application Services Software Hardware Version: oe574-4.4.5.5 Cisco Wide Area Application Services (accelerator-k9) Software Release 4.4.5 (build b5 Feb  4 2012)  "
MIB2-DAN-MIB-ADMIN,1.3.6.1.2.1.1.3.0,sysUpTime.0,503697000
IF-MIB,1.3.6.1.2.1.2.1.0,ifNumber.0,3
Anybody else have experience this kind of issue ? Could it be that the OID has changed for inline interfaces ? Any help/suggestions are welcome.
Marc
