How to program Aironet 1200 for 3 VLANs
Answered Question
May 16th, 2012
Hello. I'll admit to being a Cisco IOS newbie up-front.
I work in a small private high school. We had two dozen Aironet 1200 access points and a controller donated to us from a local hospital that no longer needed them. My boss would like me to set one up with 3 VLANs:
- encrypted VLAN for staff
- encrypted VLAN for students
- unencrypted VLAN for guests
Ultimately, we'd like the staff VLAN to have access to all internal network resources, the student VLAN to have access to several pre-defined printers, and the guest VLAN is web-only access. Whether the controller we were given will accommodate that, we won't know until we get one Aironet 1200 programmed and connected to the controller. For the time being, I just want to get this access point programmed with the 3 VLANs.
I'm easily able to get it running a single SSID (non-VLAN) network and confirm that I can use that network fine. However, I need to set up these 3 VLANs and am hoping someone can walk me through programming it. I can connect to it via telnet if that'll let me program it faster.
Any suggestions? help?
Correct Answer by maldehne about 4 years 9 months ago
Hello David
I would be more than glad to contribute to this.
Lets assume the following scenario , you have three ssids:
ssid1 : staff --> vlan1 wpa-psk
ssid 2:students -->vlan2 wep
ssid3:guests-->vlan3 open authentication
Assuming vlan 1 :192.168.1.0/24
                vlan 2:192.168.2.0/24
                vlan 3:192.168.3.0/24
L3 Switch ----- AP
AP(config)#dot11 ssid staff
               # vlan 1
               #authentication open
              #authentication key-management wpa
              #exit
AP(config)#dot11 ssid students
              #vlan 2
              #exit
AP(config)#dot11 ssid guests
               #vlan 3
              #guest-mode
              #exit
AP(config)#interface dot11radio 0
               # encryption vlan 1 mode ciphers tkip
               #encryption vlan 2 mode wep mandatory
               # encryption vlan 2 key 1 size 128bit .......
               #ssid staff
               #ssid students
               # ssid guests
               #no shut
               #exit
* Assuming vlan 1 is the trunk native vlan *
AP(config)#interface d0.1
              #encapsulation dot1q 1 native
              #bridge-group 1
             #exit
AP(config)#interface d0.2
               #encapsulation dot1q 2
              #bridge-group 2
             #exit
AP(config)#interface d0.3
               #encapsulation dot1q 3
              #bridge-group 3
             #exit
AP(config)#interface fa0.1
              #bridge-group 1
             #exit
AP(config)#interface fa0.2
              #bridge-group 2
             #exit
AP(config)#interface fa0.3
              #bridge-group 3
             #exit
AP(config)#interface bvi1
               #ip add 192.168.1.2 255.255.255.0
               # no shut
On the Switch:
SW(config)# vlan 1
                 #vlan 2
                 # vlan 3
SW(config)# interface vlan 1
                # ip add 192.168.1.1 255.255.255.0
                # no shut
               #exit
SW(config)# interface vlan 2
                # ip add 192.168.2.1 255.255.255.0
                # no shut
               #exit
SW(config)# interface vlan 3
                # ip add 192.168.3.1 255.255.255.0
                # no shut
               #exit
* Now configure the switch port connecting the AP as dot1q trunk with native vlan being 1*
SW(config-if)#switchport trunk encapsulation dot1q
                   # switchport trunk native vlan 1
                   #switchport mode trunk
                   # exit
Make sure that you define DHCP pools for clients in the various vlans which i assume you already have it.
I hope this has been informative to you.
Please make sure to rate correct answers
Overall Rating: 5 (1 ratings)
Scott Fella Wed, 05/16/2012 - 08:14
David,
What model/part # is your AP and wlc? We need this information first to see if the ap and wlc are compatible.
david.allie.2357 Thu, 05/17/2012 - 07:22
Scott,
The Aironet 1200 is model AIR-AP1231G-A-K9. The controller is the Cisco 1130 Wireless LAN Solution Engine.
-- David
david.allie.2357 Thu, 05/17/2012 - 09:03
Wow, I had a feeling that this project was going to be problematic. I'm going to look at the info/link you shared and will try to program the Aironet 1200 on my desk. I'll let you know tomorrow how it goes.
Thanks.
Correct Answer
maldehne Thu, 05/17/2012 - 09:44
Hello David
L3 Switch ----- AP
               # vlan 1
              #exit
              #vlan 2
              #exit
               #vlan 3
              #guest-mode
              #exit
               #ssid staff
               #ssid students
               # ssid guests
               #no shut
               #exit
              #bridge-group 1
             #exit
              #bridge-group 2
             #exit
              #bridge-group 3
             #exit
              #bridge-group 1
             #exit
              #bridge-group 2
             #exit
              #bridge-group 3
             #exit
               # no shut
On the Switch:
SW(config)# vlan 1
                 #vlan 2
                 # vlan 3
                # no shut
               #exit
                # no shut
               #exit
                # no shut
               #exit
                   # exit
david.allie.2357 Fri, 05/18/2012 - 07:16
Thanks maldehne, these are the commands I finally used for testing purposes, based on your suggestion:
enable
configure terminal
interface dot11radio0
ssid chs-staff
vlan 1
authentication open
encryption vlan 1 mode wep mandatory
encryption vlan 1 key 1 size 128 11111111111111111111111111 transmit-key
exit
interface dot11radio0.1
no ip route-cache
bridge-group 1
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
exit
interface fastEthernet0.1
no ip route-cache
bridge-group 1
exit
ssid chs-students
vlan 2
authentication open
encryption vlan 2 key 1 size 128 22222222222222222222222222 transmit-key
exit
interface dot11radio0.2
no ip route-cache
bridge-group 2
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
exit
interface fastEthernet0.2
no ip route-cache
bridge-group 2
exit
ssid chs-guests
vlan 3
authentication open
guest-mode
exit
interface dot11radio0.3
no ip route-cache
bridge-group 3
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
exit
interface fastEthernet0.3
no ip route-cache
bridge-group 3
exit
station role root
preamble-short
dot11 extension aironet
no shutdown
end
copy running-config startup-config
I'm able to connect on all three networks. Now, we'll set up the DHCP pools, configure the switch for the 3 VLANs, and add rules to the firewall to specify what resources can/cannot be accessed depending on role.
Thanks everyone!
