Cisco Jabber and SCCP Deskphone
Answered Question
May 16th, 2012
Hey Guys,
Need help here. I have got the same extension on botht he cisco jabber and sccp extension. But I cant get both these to ring at the same time.
Any suggestions....
Oh yeah I am using CME
Correct Answer by Paolo Bevilacqua about 4 years 10 months ago
That is supported in CME 9.0
That means you will need and ISR G2 to use the features. It will never work on an ISR G1 router.
Correct Answer by Jaime Valencia about 4 years 10 months ago
Support for Cisco Jabber
Cisco Unified CME 8.6 and later versions support Cisco Jabber. The  softphone SIP client is an iPhone application and works as a SIP  softphone. The SIP softphone client is capable of supporting VoIP over  WLAN. Cisco Unified CME 8.6 supports supplementary services such as  Hold, Resume, Transfer, Call Park, and Call Pickup for the softphone SIP  client.
Note
Shared line, conference, and hand-off call to GSM  are not supported.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (2 ratings)
Correct Answer
Jaime Valencia Wed, 05/16/2012 - 09:00
  • Cisco Employee,
  • Hall of Fame,
    2011
Note
java
Correct Answer
Paolo Bevilacqua Wed, 05/16/2012 - 09:23
  • Hall of Fame,
    Founding Member
Related Content
