Warning message
MacBook Pro camera - "movi can not connect to your camera"
Answered Question
Jan 17th, 2012
I have a 17" unibody MacBook Pro and "movi can not connect to your camera".  I have no oher applications open.  What can I do to get Movi to recognize my built in camera?
Correct Answer by Martin Koch about 5 years 7 months ago
If you have trouble I would anyhow try it with the latest version.
Lion (OS X 10.7) is officially first supported by Movi 4.3, or now called
"Cisco Jabber Video for TelePresence (Movi)"
You can download Jabber TP 4.3 under the following link, it shall work with older deployments as well,
but in case ask your movi provider / it department what they say about a different version.
http://www.cisco.com/cisco/software/release.html?mdfid=283613653&catid=280789323&softwareid=280886992&release=4.3.12.13351&rellifecycle=&relind=AVAILABLE&reltype=latest
Please vote answers and set the thread to answered if it is!
Overall Rating: 5 (3 ratings)
Martin Koch Tue, 01/17/2012 - 11:25
  • Red, 2250 points or more
Some more info might be helpful (os version, movi version, exact model type, if other devices are connected, ...)
Just tried it with my mba under lion, I can even have facetime and movi open at the same time accessing the selfview of the camera (facetime with a cropped mirrored and movi 4.2 with a standard view)
Can other applications access the cam? Did you try closing all other apps (activity monotitor or option comand esc can help you there)? Does you camera show up as a usb device in the system info? Did you check that no other user account
has some active connection to the cam? is the small LED besides the cam on?
mjwagneriu Tue, 01/17/2012 - 11:49
Mac OS 10.7.2
2.66 Ghz Intel Core 2 Duo Unibody MacBook Pro
8GB RAM
Movi Version 4.0 build 8151
All other camera applications work just fine.  Movi is the only application that does not recognize the camera.
My account is the only account on the laptop.
Correct Answer
Martin Koch Tue, 01/17/2012 - 15:18
Martin Koch Wed, 01/18/2012 - 07:06
Interesting, I thought the same about your name as well!
Great to read that your issue seems to be fixed!
rfrome Thu, 01/19/2012 - 12:02
Martin,
Under Preferences for Movi, did you try selecting Devices -> Video Input, and then Selecting the FaceTime Camera (Built in) option?
davidhale01 Fri, 02/10/2012 - 09:50
Hi Martin,
I am having the same issue as the other Martin.  MacBook Air 11'', I had MOVI and it worked fine with the internal camera on SnowLeopard.  I upgraded to Lion and it does not recognize my internal camera.  I have downloaded and installed version 4.3 as you suggested, but I still have the same issue.  My camera works fine with Facetime, Photobooth, and Skype, just not with MOVI.  In the selection box for the audio & microphone, it says "Built-in-microphone", "Built-in-output", but in the video device it says "automatic selection" and the dropdown box doesnt' give you any other choices.
Any ideas?
Thanks, David
SOLUTION FOUND:  At one point in time I had installed "iglasses" to test it out and then didnt' want to buy it, so uninstalled it.   Apparently I had not completely uninstalled it and this was causing conflicts with MOVI.   I re-downloaded the free demo of "iGlasses", and then uninstalled it, and it worked fine.
Martin Koch Fri, 02/10/2012 - 13:01
Good that you found a sulution, also check that you are useing the right application.
"Movi" will not be replaced by "Jabber Video", so if you had Movi autostarted or open it manually,
this is not 4.3, you have to check that you start the "Jabber Video" application and best trash "Movi"
MEK
Related Content
