Multiple Radius Servers on AP1142
May 17th, 2012
Hi guys
I was wondering if the following is possible
I currently have a Radius Server acting as the authentication endpoint for a one of my SSID's
I now wish to implement a new SSID that uses a different Radius server.
I noticed that in the AP settings one can configure order of preference for which Radius server to authenticate with however I would like to point my new SSID to use the new Radius server that I wish to implement.
Is this possible to setup?
Your help is much apppreciated.
Kind Regards
Mohamed
Overall Rating: 4 (3 ratings)
Scott Fella Thu, 05/17/2012 - 04:43
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
If you have a wlc you can, but I don't thing you can if the APs are autonomous.
Mohamed Hamid Thu, 05/17/2012 - 04:59
Ah, I currently dont have a wlc in place, I have 10 standalone AP's which I have copied the same config over to each manually.
You definately sure there is no way of getting seperate SSIDs to use seperate radius servers?
maldehne Fri, 05/18/2012 - 00:46
  • Cisco Employee,
Who said so , ofcourse we can?
Lets assume the following sdenarios, I have an AP with two ssids:
ssid1 configured for EAP Authentication , where the user credentials should be submitted agains the following radius servers:
192.168.1.1
192.168.1.2
ssid2 is configured for EAP Authentication as well, but this time the authentication is submitted to the following RADIUS servers:
192.168.1.3
192.168.1.4
How to configure it?
AP(config)# aaa new-model
AP(config)#radius-server host 192.168.1.1 auth-port 1812 acct-port 1813 key ......
AP(config)#radius-server host 192.168.1.2 auth-port 1812 acct-port 1813 key ......
AP(config)#radius-server host 192.168.1.3auth-port 1812 acct-port 1813 key ......
AP(config)#radius-server host 192.168.1.4 auth-port 1812 acct-port 1813 key ......
AP(config)#aaa group server radius group1
               #server 192.168.1.1
               #server 192.168.1.2
               #exit
AP(config)#aaa group server radius group2
               #server 192.168.1.3
               #server 192.168.1.4
               #exit
AP(config)#dot11 ssid ssid1
               #authenticaton open eap eap1
               #authentication network-eap eap1
               #authentication key-management wpa
               #vlan x
               #exit
AP(config)#dot11 ssid ssid2
               #vlan y
               #authentication open eap eap2
               #authentication network-eap eap2
               #exit
AP(config)#aaa authentication login eap1 group group1
AP(config)#aaa authentication login eap2 group group2
Then you complete the other config parts
Please make sure to rate correct answers
Scott Fella Fri, 05/18/2012 - 00:49
  • Hall of Fame,
    2017 Wireless
Thanks for the correction. Didn't think it was possible.
Mohamed Hamid Fri, 06/08/2012 - 06:02
Hi Mate
Thank you very much for your reply, I have only just go on to implement this.. I am having an issue when I run
it seems it doesnt like the number 1 it says invalid input detected although I have created this group without the space
UPDATE:
Ok I resolved the above by not using numbers in the naming however i believe you said there were other config parts involved? because I am still not able to radius auth I have the following defined
aaa group server radius dmz
server 192.168.9.90 auth-port 1645 acct-port 1646
aaa authentication login eap1 group dmz
dot11 ssid CDN02_test
   vlan 4
   authentication open eap eap1
   authentication key-management wpa version 2
   dot1x credentials AP2
   dot1x eap profile test
   mbssid guest-mode
Message was edited by: Mohamed Hamid
nkarthikeyan Sun, 06/10/2012 - 03:34
  • Gold, 750 points or more
you can configure something like this
aaa group server radius ssid1
server auth-port 1812 acct-port 1813
aaa group server radius ssid2
aaa authentication login eap_1 group ssid1
aaa authentication login wds_infra_methods group ssid1
aaa authentication login wds_client_methods group ssid1
aaa authentication login eap_1 group ssid2
aaa authentication login wds_infra_methods group ssid2
aaa authentication login wds_client_methods group ssid2
dot11 ssid 1
   authentication open eap eap_1
   authentication network-eap eap_1
dot11 ssid 2
   authentication open eap eap_2
   authentication network-eap eap_2
Mohamed Hamid Wed, 06/13/2012 - 04:56
Hi Guys
Thank you for your replies
I have followed the above and I am pretty sure I have followed it correctly, however users still cannot auth onto the secondary RADIUS server. In the logs I can see the following
Jun 13 09:26:10.095: %DOT11-7-AUTH_FAILED: Station 442a.60f5.c7da Authentication failed
Jun 13 09:26:22.254: %RADIUS-4-RADIUS_DEAD: RADIUS server :1645,1646 is not responding.
Jun 13 09:26:22.255: %RADIUS-4-RADIUS_ALIVE: RADIUS server :1645,1646 is being marked alive.
I have done some research and came accross this article
https://supportforums.cisco.com/docs/DOC-3480
The following is output of the version of my AP
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 16-Sep-09 18:09 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA, RELEASE SOFTWARE (fc3)
AP10 uptime is 4 days, 1 hour, 41 minutes
System restarted at 11:13:09 GMT Sat Jun 9 2012
System image file is "flash:/c1140-k9w7-mx.124-21a.JA1/c1140-k9w7-mx.124-21a.JA1"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-AP1142N-E-K9     (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1527W1T5
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 30:E4:DB:45:56:66
Part Number                          : 73-12836-02
PCA Assembly Number                  : 800-33767-02
PCA Revision Number                  : A0
PCB Serial Number                    : FOC152447U1
Top Assembly Part Number             : 800-33775-01
Top Assembly Serial Number           : FCZ1527W1T5
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1142N-E-K9
Configuration register is 0xF
maldehne Wed, 06/13/2012 - 06:08
  • Cisco Employee,
well , in the frist place please make sure that your radius server is logging something on the failed authentication.
If not , there are two possibilities , either the request is not received at the radius server side or it is received and the reply is not being received on the AP side or not sent by the server at all.
So , to figure out what is going on ,
traces on AP and traces on server side while the issue is happenning.
Cheers
Mohamed Hamid Wed, 06/13/2012 - 07:27
thank you for your reply mate.
Just a quick one.. when you say traces, you mean using a tool like tcpdump right?
How would I be able to run this on the AP?
Much appreciated
Mohamed Hamid Wed, 06/13/2012 - 08:42
This is quite weird, I changed some rules on my firewall to allow all traffic through and now I am presented with a self assigned cert from my radius server which means some traffic is passing through however  leads me to beleive that the actual radius traffic that passes the ticket accross is not working.
I can open a telnet session from the AP to the server fine..
I keep getting this
Jun 13 15:37:43.317: %DOT11-7-AUTH_FAILED: Station 442a.60f5.c7da Authentication failed
Jun 13 15:37:43.319: %DOT11-4-MAXRETRIES: Packet to client 442a.60f5.c7da reached max retries, removing the client
Jun 13 15:38:13.444: %DOT11-7-AUTH_FAILED: Station 442a.60f5.c7da Authentication failed
Jun 13 15:38:26.998: %DOT11-7-AUTH_FAILED: Station 442a.60f5.c7da Authentication failed
Jun 13 15:40:52.620: %DOT11-7-AUTH_FAILED: Station 442a.60f5.c7da Authentication failed
AP10#
maldehne Wed, 06/13/2012 - 22:58
  • Cisco Employee,
First of all , how can you collect sniffer traces :
Very simple have two span port sessions on switch ports connected to AP and RADIUS server.
Have two laptobs with wireshark installed on each .
connect those two pcs to other switch ports where one can receive traffic from span port session ojne and another can receive traffic from span port session 2.
Collect the traces results and send them back to me.
Mohamed Hamid Thu, 06/14/2012 - 02:25
Hi Mate
Ok what I done in the end is put my freeradius server in debug mode and then analyse what was happening.
It seems like it is trying to do a MSCHAPv2 authentication which is failing. When I carry out a radtest it uses LDAP and works fine. I have pasted both debug outputs below and removed ip's and usernames.
So my question is, how can I get the AP to use LDAP instead of MSCHAP?
Cisco AP Output using MSCHAP
[ldap] user authorized to use remote access\
  [ldap] ldap_release_conn: Release Id: 0\
++[ldap] returns ok\
++[expiration] returns noop\
++[logintime] returns noop\
++[pap] returns noop\
Found Auth-Type = MSCHAP\
+- entering group MS-CHAP \{...\}\
[mschap] No Cleartext-Password configured.  Cannot create LM-Password.\
[mschap] No Cleartext-Password configured.  Cannot create NT-Password.\
[mschap] Told to do MS-CHAPv2 for with NT-Password\
[mschap] FAILED: No NT/LM-Password.  Cannot perform authentication.\
[mschap] FAILED: MS-CHAP2-Response is incorrect\
++[mschap] returns reject\
Failed to authenticate the user.\
\} # server inner-tunnel\
[ttls] Got tunneled reply code 3\
    MS-CHAP-Error = "tE=691 R=1"\
[ttls] Got tunneled Access-Reject\
[eap] Handler failed in EAP/ttls\
[eap] Failed in EAP select\
++[eap] returns invalid\
Using Post-Auth-Type Reject\
+- entering group REJECT \{...\}\
[attr_filter.access_reject]     expand: %\{User-Name\} -> \
attr_filter: Matched entry DEFAULT at line 11\
++[attr_filter.access_reject] returns updated\
Delaying reject of request 3 for 1 seconds\
Going to the next request\
Waking up in 0.9 seconds.\
Sending delayed reject for request 3\
Sending Access-Reject of id 120 to port 14053\
RADTEST Output using LDAP
Found Auth-Type = LDAP
+- entering group LDAP {...}
[ldap] login attempt by "username" with password "password"
[ldap] user DN: uid=username,cn=users,dc=digital,dc=dc,dc=dc,dc=dc
  [ldap] (re)connect to fqdn:389, authentication 1
  [ldap] bind as uid=username,cn=users,dc=digital,dc=dc,dc=dc,dc=dc/password to fqdn:389
  [ldap] waiting for bind result ...
  [ldap] Bind was successful
[ldap] user username authenticated succesfully
++[ldap] returns ok
+- entering group post-auth {...}
++[exec] returns noop
Sending Access-Accept of id 80 to port 45207
Related Content
Trending Topics - Security & Network
