International FAX Not Going!!
May 17th, 2012
Hi Team,
I have a problem in which the international fax is not going. The local and std fax is going without any problem. The fax machine is connected to VG202 gateway. We have a H323 gateway and CUCM 8.5. I attached an analog phone to the fax port and tried calling an international number and the call is going without any problem. When I try to send an international fax, it gives me an error message saying "the call cannot be completed as dialed". I checked the css and partition in cucm and it is correct. This is the fresh installation and this is the first time we are sending an international fax.
I have attached the voice gateway, vg202, debug outputs of debug vtsp all and debug voice ccapi inout outputs.
For debug commands the dialled number is 0016786246950.
Thanks in advance.
Overall Rating: 5 (2 ratings)
Chris Deren Thu, 05/17/2012 - 06:19
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Make sure the fax machine is not pre-programmed with off-net access code, i.e. 9, if so either remove it or do not dial it.
Can you post debug voice dialpeer from the GW?
Chris
khanfawaz Thu, 05/17/2012 - 06:45
Hi Chris,
Thanks for the reply. I use 9 to access the PSTN while calling local or long distance or international numbers. I do not think fax machine is pre-programmed as you said. I have pasted the output of debug voice dialpeer below. The number i dialed is 0016786246950. Only difference in calling local or long distance from international is I use '#' sign after dialing international numbers.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.05.17 19:03:39 =~=~=~=~=~=~=~=~=~=~=~=
User Access Verification
Username: locuz
Password:
iec-v-gw-01>en
Password:
iec-v-gw-01#ter mon
iec-v-gw-01#debug voice dialp
iec-v-gw-01#debug voice dialpeer
voip dialpeer default debugging is on
iec-v-gw-01#
May 17 13:35:06.168: //-1/8066DD1B4C1A/DPM/dpAssociateIncomingPeerCore:
   Calling Number=30666, Called Number=0016786246950, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=15
May 17 13:35:06.168: //-1/8066DD1B4C1A/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
May 17 13:35:06.168: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=0016786246950, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=0016786246950
   Result=Success(0) after DP_MATCH_DEST
May 17 13:35:06.168: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=0016786246950, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
May 17 13:35:06.168: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:35:06.168: //-1/8066DD1B4C1A/DPM/dpMatchPeersCore:
May 17 13:35:06.168: //-1/8066DD1B4C1A/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
   Calling Number=0016786246950, Called Number=0016786246950, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:35:06.168: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=0016786246950, Called Number=, Voice-Interface=0x0,
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
   dialstring=0016786246950, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:35:15.036: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=30666, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=30666
May 17 13:35:15.036: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 17 13:35:15.036: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=13
     2: Dial-peer Tag=14
     3: Dial-peer Tag=15
     4: Dial-peer Tag=1
     5: Dial-peer Tag=2
     6: Dial-peer Tag=3
     7: Dial-peer Tag=5
     8: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:35:15.186: %ISDN-6-CONNECT: Interface Serial0/1/1:2 is now connected to 0016786246950 N/A
May 17 13:35:15.186: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 17 13:35:15.186: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 17 13:35:15.186: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=13
     2: Dial-peer Tag=14
     3: Dial-peer Tag=15
     4: Dial-peer Tag=1
     5: Dial-peer Tag=2
     6: Dial-peer Tag=3
     7: Dial-peer Tag=5
     8: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:35:38.915: %ISDN-6-DISCONNECT: Interface Serial0/1/1:0  disconnected from 7204397113 , call lasted 126 seconds
May 17 13:35:45.249: //-1/00541C334D1A/DPM/dpAssociateIncomingPeerCore:
   Calling Number=30004, Called Number=9741362955, Voice-Interface=0x0,
May 17 13:35:45.249: //-1/00541C334D1A/DPM/dpMatchSafModulePlugin:
May 17 13:35:45.249: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=9741362955, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=9741362955
May 17 13:35:45.249: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=9741362955, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
May 17 13:35:45.249: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:35:45.249: //-1/00541C334D1A/DPM/dpMatchPeersCore:
May 17 13:35:45.249: //-1/00541C334D1A/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
   Calling Number=9741362955, Called Number=9741362955, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:35:45.249: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=9741362955, Called Number=, Voice-Interface=0x0,
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
   dialstring=9741362955, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:35:45.841: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=30004, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=30004
May 17 13:35:45.841: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 17 13:35:45.841: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=13
     2: Dial-peer Tag=14
     3: Dial-peer Tag=15
     4: Dial-peer Tag=1
     5: Dial-peer Tag=2
     6: Dial-peer Tag=3
     7: Dial-peer Tag=5
     8: Dial-peer Tag=6
May 17 13:35:45.843: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 17 13:35:45.843: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 17 13:35:45.843: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:36:00.932: %ISDN-6-DISCONNECT: Interface Serial0/1/1:2  disconnected from 0016786246950 , call lasted 45 seconds
May 17 13:36:30.775: //-1/80C8EE4D4E1A/DPM/dpAssociateIncomingPeerCore:
May 17 13:36:30.775: //-1/80C8EE4D4E1A/DPM/dpMatchSafModulePlugin:
May 17 13:36:30.777: //-1/80C8EE4D4E1A/DPM/dpMatchSafModulePlugin:
May 17 13:36:30.777: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 17 13:36:30.777: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 17 13:36:30.777: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:36:30.777: //-1/80C8EE4D4E1A/DPM/dpMatchPeersCore:
May 17 13:36:30.777: //-1/80C8EE4D4E1A/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:36:30.777: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:36:39.003: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 17 13:36:39.003: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 17 13:36:39.003: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=13
     2: Dial-peer Tag=14
     3: Dial-peer Tag=15
     4: Dial-peer Tag=1
     5: Dial-peer Tag=2
     6: Dial-peer Tag=3
     7: Dial-peer Tag=5
     8: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:36:39.105: %ISDN-6-CONNECT: Interface Serial0/1/1:0 is now connected to 0016786246950 N/A
May 17 13:36:39.105: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 17 13:36:39.105: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 17 13:36:39.105: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=13
     2: Dial-peer Tag=14
     3: Dial-peer Tag=15
     4: Dial-peer Tag=1
     5: Dial-peer Tag=2
     6: Dial-peer Tag=3
     7: Dial-peer Tag=5
     8: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:37:14.250: %ISDN-6-DISCONNECT: Interface Serial0/1/1:0  disconnected from 0016786246950 , call lasted 35 seconds
May 17 13:37:14.932: //-1/80A628684F1A/DPM/dpAssociateIncomingPeerCore:
   Calling Number=30001, Called Number=41477788, Voice-Interface=0x0,
May 17 13:37:14.932: //-1/80A628684F1A/DPM/dpMatchSafModulePlugin:
May 17 13:37:14.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=41477788, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=41477788
May 17 13:37:14.932: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=41477788, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
May 17 13:37:14.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:37:14.932: //-1/80A628684F1A/DPM/dpMatchPeersCore:
May 17 13:37:14.932: //-1/80A628684F1A/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
   Calling Number=41477788, Called Number=41477788, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:37:14.932: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=41477788, Called Number=, Voice-Interface=0x0,
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
   dialstring=41477788, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:37:15.204: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=30001, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=30001
May 17 13:37:15.204: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 17 13:37:15.204: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=13
     2: Dial-peer Tag=14
     3: Dial-peer Tag=15
     4: Dial-peer Tag=1
     5: Dial-peer Tag=2
     6: Dial-peer Tag=3
     7: Dial-peer Tag=5
     8: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:37:19.373: //-1/0097236B501A/DPM/dpAssociateIncomingPeerCore:
   Calling Number=30367, Called Number=41440020, Voice-Interface=0x0,
May 17 13:37:19.373: //-1/0097236B501A/DPM/dpMatchSafModulePlugin:
May 17 13:37:19.373: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=41440020, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=41440020
May 17 13:37:19.373: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=41440020, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
May 17 13:37:19.373: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:37:19.373: //-1/0097236B501A/DPM/dpMatchPeersCore:
May 17 13:37:19.373: //-1/0097236B501A/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
   Calling Number=41440020, Called Number=41440020, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:37:19.373: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=41440020, Called Number=, Voice-Interface=0x0,
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
   dialstring=41440020, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:37:19.646: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=30367, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=30367
May 17 13:37:19.646: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 17 13:37:19.646: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=13
     2: Dial-peer Tag=14
     3: Dial-peer Tag=15
     4: Dial-peer Tag=1
     5: Dial-peer Tag=2
     6: Dial-peer Tag=3
     7: Dial-peer Tag=5
     8: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:37:31.987: %ISDN-6-CONNECT: Interface Serial0/1/1:0 is now connected to 41477788 N/A
May 17 13:37:31.987: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 17 13:37:31.987: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 17 13:37:31.987: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=13
     2: Dial-peer Tag=14
     3: Dial-peer Tag=15
     4: Dial-peer Tag=1
     5: Dial-peer Tag=2
     6: Dial-peer Tag=3
     7: Dial-peer Tag=5
     8: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:37:44.125: //-1/80490A7A511A/DPM/dpAssociateIncomingPeerCore:
May 17 13:37:44.125: //-1/80490A7A511A/DPM/dpMatchSafModulePlugin:
May 17 13:37:44.125: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 17 13:37:44.125: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 17 13:37:44.125: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:37:44.125: //-1/80490A7A511A/DPM/dpMatchPeersCore:
May 17 13:37:44.125: //-1/80490A7A511A/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:37:44.125: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:37:44.127: //-1/80490A7A511A/DPM/dpMatchPeersCore:
May 17 13:37:44.127: //-1/80490A7A511A/DPM/dpMatchSafModulePlugin:
May 17 13:37:44.127: //-1/80490A7A511A/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:37:53.028: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 17 13:37:53.028: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 17 13:37:53.028: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=13
     2: Dial-peer Tag=14
     3: Dial-peer Tag=15
     4: Dial-peer Tag=1
     5: Dial-peer Tag=2
     6: Dial-peer Tag=3
     7: Dial-peer Tag=5
     8: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:37:53.128: %ISDN-6-CONNECT: Interface Serial0/1/1:4 is now connected to 0016786246950 N/A
May 17 13:37:53.128: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 17 13:37:53.128: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 17 13:37:53.128: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=13
     2: Dial-peer Tag=14
     3: Dial-peer Tag=15
     4: Dial-peer Tag=1
     5: Dial-peer Tag=2
     6: Dial-peer Tag=3
     7: Dial-peer Tag=5
     8: Dial-peer Tag=6
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
     2: Dial-peer Tag=2
     3: Dial-peer Tag=3
     4: Dial-peer Tag=5
     5: Dial-peer Tag=6
May 17 13:38:27.756: %ISDN-6-DISCONNECT: Interface Serial0/1/1:0  disconnected from 41477788 , call lasted 55 seconds
May 17 13:38:28.080: %ISDN-6-DISCONNECT: Interface Serial0/1/1:4  disconnected from 0016786246950 , call lasted 34 secondsun all
All possible debugging has been turned off
iec-v-gw-01#
May 17 13:39:09.589: %ISDN-6-CONNECT: Interface Serial0/1/1:2 is now connected to 9880912727 N/Aexit
Ayodeji Okanlawon Thu, 05/17/2012 - 07:06
    2017 IP Telephony
You dont have a problem with the call setup. The inbound call leg matches dial-peer 15 and the outbound matches dial-peer 1. The call connects..but there is no fax negotiation taking place. Look at the my posts below and respond to my suggestions
Ayodeji Okanlawon Thu, 05/17/2012 - 06:32
    2017 IP Telephony
Hi Khanfawaz,
I am looking at your traces now and I can see that you dont have a problemw ith CSS, PT.
The call connects and it is then disconnected by your side. Either CUCM or gateway..we shall find out.
May 17 12:42:04.033: %ISDN-6-CONNECT: Interface Serial0/1/1:1 is now connected to 0016786246950 N/A
May 17 12:42:04.033: //27755/0071E1ADE019/CCAPI/cc_api_call_connected:
Here we see the call leg that disconnected the call: which is the inbound leg to the gateway, so its coming from CUCM.
May 17 12:42:49.679: //27754/0071E1ADE019/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x209A8568, Call Id=27754
Now we will look deeper into the fax negotitation...
Ayodeji Okanlawon Thu, 05/17/2012 - 06:40
    2017 IP Telephony
I have looked at your fax negotitation, debug and there is no fax negotiation at all....Here is a sample of your debug output..
May 17 12:29:18.319: %ISDN-6-DISCONNECT: Interface Serial0/2/0:0  disconnected from 0016786246950 , call lasted 22 seconds
Here is a sample of fax negotiation from my gateway
066311: .Apr 29 15:03:36.924 BST: //357653/EE6891D7BA9D/VTSP:(1/0:15):-1:8:2/vtsp_dsm_call_mod_done_cb:
066312: .Apr 29 15:03:36.924 BST: MGCP Packet sent to 10.105.40.174:2427--->
200 6298 OK
066313: .Apr 29 15:03:38.432 BST: //357653/EE6891D7BA9D/VTSP:(1/0:15):-1:8:2/vtsp_dsm_media_event_cb:
   Event=E_DSM_DSP_MODEM_TONE
066314: .Apr 29 15:03:38.432 BST: //357653/EE6891D7BA9D/VTSP:(1/0:15):-1:8:2/vtsp_dsm_feature_notify_cb:
   Feature ID=4, Feature Status=1
066315: .Apr 29 15:03:38.432 BST: //357653/EE6891D7BA9D/VTSP:(1/0:15):-1:8:2/vtsp_dsm_call_mod_done_cb:
066316: .Apr 29 15:03:38.436 BST:          Pt:100    Evt:192     Pkt:B9 8B C0  >>
066317: .Apr 29 15:03:38.452 BST:          Pt:100    Evt:192     Pkt:B9 8B C0  >>
066318: .Apr 29 15:03:38.472 BST:          Pt:100    Evt:192     Pkt:B9 8B C0  >>
++++Looking further I also see that your call is using FAX_Rate, even though your config Yopu want to use t.38/pass through++++
You cant have both t.38/pass through++ You need to decide what you want to use. And in this case none is even been used.
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
modem passthrough nse codec g711alaw
+++Here we see FAX_RATE been advertised+++
May 17 12:42:04.013: //27755/0071E1ADE019/CCAPI/cc_api_caps_ack:
   Destination Interface=0x209A8568, Destination Call Id=27754, Source Call Id=27755,
   Caps(Codec=g711alaw(0x2), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
If you want to use mass through with nse switch over, then configure the following
dial-peer voice 15 voip
modem pass-through nse codec g711ulaw
fax rate disable
Then do a test call and send the ff: debug:
debug h225 asn1 d
ebug h245 asn1
debug voip vtsp all
debug voip rtp session named-event
Chris Deren Thu, 05/17/2012 - 07:30
  • Hall of Fame,
Fax does not get negotiated becuase it never makes it to PSTN hance the Annouciator message he is getting from CUCM.
If you are using 9 for off-net access code, I do not seee that in any dial-peers, is CUCM configured to prefix the 9 somewhere so it knows to match proper PSTN route pattern?
Chris
Ayodeji Okanlawon Thu, 05/17/2012 - 07:44
    2017 IP Telephony
Chris,
here is the debug voip ccapi.which shows the call made it to the PSTN was connected and disconnected after a few seconds. It is possible that the call didnt stay long enough for fax negotiation to happen
++++Call setup on incomign DP=15+++
cc_api_call_setup_ind_common:
   cisco-username=FAX
   ----- ccCallInfo IE subfields -----
   cisco-ani=30666
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=0016786246950
Calling Number=30666,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=0016786246950(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=15, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=27754
+++outoging call leg usinf DP=1++++
ay 17 12:41:55.807: //27754/0071E1ADE019/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=FAX
   cisco-ani=30666
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=0016786246950
Called Number=0016786246950(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1
y 17 12:41:55.807: //27754/0071E1ADE019/CCAPI/ccSaveDialpeerTag:   Outgoing Dial-peer=1
++Call proceeding++++
May 17 12:42:00.964: //27755/0071E1ADE019/CCAPI/cc_api_call_proceeding:
   Interface=0x21A25C88, Progress Indication=NULL(0)
++alert+++
May 17 12:42:04.003: //27755/0071E1ADE019/CCAPI/cc_api_call_alert:
++ringback+++
   Interface=0x21A25C88, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
May 17 12:42:04.003: //27754/0071E1ADE019/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
May 17 12:42:04.003: //27755/0071E1ADE019/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
+++joining two callegs callId=27754, 27755+++Conf Create
May 17 12:42:04.003: //27754/0071E1ADE019/CCAPI/ccConferenceCreate:
   (confID=0x2273A194, callID1=0x6C6A, gcid=0-0-0-0, tag=0x0)
May 17 12:42:04.003: //27755/0071E1ADE019/CCAPI/ccConferenceCreate:
   (confID=0x2273A194, callID2=0x6C6B, gcid=0-0-0-0, tag=0x0)
   Conference Id=0x2273A194, Call Id1=27754, Call Id2=27755, Tag=0x0
May 17 12:42:04.003: //27754/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
May 17 12:42:04.003: cc_api_get_xcode_stream : 4701
May 17 12:42:04.003: //27754/0071E1ADE019/CCAPI/cc_api_bridge_done:
   Conference Id=0x2D82, Source Interface=0x209A8568, Source Call Id=27754,
   Destination Call Id=27755, Disposition=0x0, Tag=0x0
May 17 12:42:04.003: //27755/0071E1ADE019/CCAPI/cc_api_bridge_done:
   Conference Id=0x2D82, Source Interface=0x21A25C88, Source Call Id=27755,
   Destination Call Id=27754, Disposition=0x0, Tag=0xFFFFFFFF
May 17 12:42:04.003: //27754/0071E1ADE019/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x2D82, Destination Call Id=27755)
+++  Here the call is connected++++
So the call is definitely been connected but immediately disconnecting before fax negotiation can happen
and then a few seconds later we see the call disconnected from his side
Chris Deren Thu, 05/17/2012 - 08:01
  • Hall of Fame,
His debug is from VG202 so there is no PSTN there, his pots dial-peer are with destination pattern .T so those are matched producing what pots setup, but all these are messages to FXS ports which obviously do not do anything.
Chris
Ayodeji Okanlawon Thu, 05/17/2012 - 08:35
    2017 IP Telephony
Chris,
Debug taking from Voice gateway with Pots dial-peer and voice-cards
iec-v-gw-01>en
Password:
iec-v-gw-01#ter mon
iec-v-gw-01#
May 17 12:40:50.971: %ISDN-6-CONNECT: Interface Serial0/1/1:0 is now connected to 9986632948 N/Adebug
iec-v-gw-01#debug voice cc
iec-v-gw-01#debug voice ccapi inout
voip ccapi inout debugging is on
iec-v-gw-01#
May 17 12:41:29.801: //27750/001DF782DE19/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x209A8568, Call Id=27750
iec-v-gw-01>en
Password:
Sh run of voice gateway with e1 cards and Pots dial-peer
iec-v-gw-01#sh run
iec-v-gw-01#sh running-config
Building configuration...
hostname iec-v-gw-01
boot-start-marker
boot-end-marker
card type e1 0 0
card type e1 0 1
card type e1 0 2
iec-v-gw-01>en
Password:
iec-v-gw-01#ter mon
Matched outbound pots dial-peer
dial-peer voice 1 pots
description "OUTBOUND TO RELIANCE PRI 1"
destination-pattern .T
port 0/1/1:15
forward-digits all
+++Matched inboud voip dial-peer+++
description "OUTBOUND TO CUCM Group 2"
  destination-pattern 30...
session target ipv4:172.20.3.4
-voice-class h323 16
dtmf-relay rtp-nte h245-alphanumeric
codec g711alaw
no vad
Ayodeji Okanlawon Thu, 05/17/2012 - 08:30
    2017 IP Telephony
Can you try and see if a normal phone can dial this number and the call stays connected.
Send a debug isdn q931 for both phone call and fax call
Ayodeji Okanlawon Thu, 05/17/2012 - 08:48
    2017 IP Telephony
Chris, I just realised that I am only assuming that this is the called number Called Number=0016786246950.
We were never told what the calling and called number is..
khanfawaz Thu, 05/17/2012 - 08:50
Hi Chris and Aokanlawon,
Thanks for your all the inputs.
@ Aokanlawon. My working hours has ended and I am at home now. I will take and send the debug output tomorrow. I was able to dial this number from an analog phone when connected to this FAX port.
@ Chris: The debug is from the voice gateway and noy from vg202.
khanfawaz Thu, 05/17/2012 - 09:18
HI,
The called number is 0016786246950 and the calling number is 080332306666.
Ayodeji Okanlawon Thu, 05/17/2012 - 09:26
    2017 IP Telephony
Khanfawaz,
The call is was looking at is
Calling Number=30666   Called Number=0016786246950
So its 30666 calling =0016786246950. Is 30666 the extension of your fax machine?
khanfawaz Fri, 05/18/2012 - 04:25
Hi aokanlawon,
Yes the calling number is 30666 and the called number is 0016786246950. Yes, 30666 is the extension of my fax machine.
In my next posts I have pasted the debug outputs of debug isdn q931.
Ayodeji Okanlawon Fri, 05/18/2012 - 04:28
    2017 IP Telephony
Ok, send debug isdn q931 for both succesful phone call and failed fax call.
khanfawaz Fri, 05/18/2012 - 04:43
I have attached debug isdn q931 for both successful international call and failed international fax. For international call the called number is 0097339583068 and calling number is 30666.
For failed international fax the called number is 0016786246950 and calling number is 30666.
Ayodeji Okanlawon Fri, 05/18/2012 - 04:59
    2017 IP Telephony
Ok I have looked at both logs and everything looks similar. The succesfull call lasted for 34s and the failed call for 17s. Did you end the succesful call?  (Thet race showed that it was diconnected from the far end.
..May 18 11:07:24.389: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8288
This is also similar to the fax call..It was disconnected from the other side..
Can you try and dial the failed fax number from another phone on your network. Can you also try and dial the succesful call from the fax machine?
khanfawaz Fri, 05/18/2012 - 05:21
The successful call was diconnected by me. I have attached the debug for failed fax number. Here the calling number is 30431 and called number is 0016786246950. Now when I call the fax number from another number (30431), I hear a fax tone and the call gets disconnected. Today I do not know the status of that remote fax machine. I have already send the debug for succesful call from fax machine.
Ayodeji Okanlawon Fri, 05/18/2012 - 05:32
    2017 IP Telephony
Ok, so we cant say we have a fax problem when the telephone-call needed for the fax call cant be established. What we have is a phone call problem. Is there another international fax that you can try? You need to try another fax to isolate what the problem is
I dialled that fax from my mobile phone and I get a fax tone and it stays up for atleast 32s. So it looks like that fax is working okay..
khanfawaz Fri, 05/18/2012 - 05:46
Just now I was able to send a international fax to another number 0015126022451. I beleive there is an issue with the remote fax which has the number 0016786246950..
Ayodeji Okanlawon Fri, 05/18/2012 - 06:05
    2017 IP Telephony
Ok so there you go. You have finally see that you do not have a problem, its the other fax or a compartibility issue between that fax and your end. So glad we made some head way. Please dont forget to rate useful posts
khanfawaz Fri, 05/18/2012 - 06:29
Hi aokanlawon,
Thanks for being extremely helpful.
@ chris: Thanks for you too.
Related Content
