Acs 5.3 - wireless conversion from 4.0
May 18th, 2012
Hi All
As previous posters may have noticed i have been given the task of moving the ACS
from 4.0 to 5.3 which turns out to be considerably different.
Sadly i have nothing to test with at the moment so am trying to work it out as best i can
before the abbreviated period of cutover begins.
I have a Service Desk group setting in 4.0
Under groups i have the group settings  and down the bottom i have the following -
(ticked )  Wireless-WCS HTTP
(ticked ) Custom Attributes
Then in the box -
virtual-domain0=CRUK
role0=LobbyAmbassador
task0=Configure Guest Users
task1=Lobby Ambassador User Preferences
Fine but that doesnt translate directly into any 5.3 settings.
I assume that i would do the following
In policy elements create a shell profile (Service Desk) with the following settings -
Privilege level 0
Custom attributes
Manually entered -
attribute              requirement              Value
virtual-domain      mandatory               virtual-domain0=CRUK
role                    mandatory               role0=LobbyAmbassador
task0                 mandatory               task0=Configure Guest Users
task1                 mandatory               task1=Lobby Ambassador User Preferences
submit that and then go to  -
Access Policies/default device admin/Authorisation
Create a new Rule
Add  the correct AD group in compound condition AD-AD1   attribute ExternalGroups  value static
in NDG:Device Type -  reference the WLC (previously created as device type with ip address)
Then in Results reference the above shell profile - Service Desk.
Sorry about the longevity but if this looks ok or rubbish can someone let me know as i wont
have much time to get it working with the real wireless
Thanks in advance
Steve
mansrini Mon, 05/21/2012 - 21:39
  • Cisco Employee,
Steve,
The process is correct.. However Iam pointing out the following mistakes
It should not be
rather it should be
virtual-domain0      mandatory               CRUK
In 4.x , virtual-domain0=CRUK means virtual-domain0 is the attribute and CRUK is the value.. Pls follow the same for all the AV pairs listed above..
-Mani
Related Content
