Warning message
Firewall Asa 5505 e Asdm (nat)
May 18th, 2012
hello all I ask an aid to solve a problem that I have a customer that I recentlyacquired.
From this account is already configured a ASA 5505.
I state that I have 0 knowledge of cisco firewalls and these days I havedocumented on the internet and reading its manual.
The firewall is working fine and there is also configured on a VPN to connectfrom the outside owners.
I tried to connect to ASA via https from a PC LAN but nothing. By reading anddocumenting I downloaded putty and I'm connected to the firewall via console.
Later I see the configuration that has been made​​.
Comparing the more info I found on the internet I see that the http server is down and you have not configured access. Provvedo and I enable him to exacta PC LAN.
Try again to connect, this time it shows the page's security certificate is invalidor I clicc not recommended, so I go out well but soon after the error can not find the page, with the explorer. I try with safari and it turns out the error http 404 or440? (if I remember correctly). I go to see if there is a bin with putty dell'asdm in flash memory and it turns out there but I can not find the file. (sorry I'm writingcarelessly, but as you know better than me, this is seen by typing certain commands)
A point I stopped because I do not want to create trouble. I would open certainports to an internal ip and then being allowed outside access from any PC on that port through public ip.
Can you help me by giving me the commands to be written in putty or I can lend a hand to pick up on the ASDM (so that the GUI definitely am I doing?)
Thanks to all who respond
hello
David
ajay chauhan Fri, 05/18/2012 - 05:07
  • Silver, 250 points or more
Hi David,
what type of vpn is configured on ASA box ?
what version of OS is running on ASA ?
Better you post full configuration here along with requirment someone for sure can tell/modify configuration which you can use.
Ajay
nonsocosamettere86 Fri, 05/18/2012 - 05:30
here the configuration:
I darkened the references of the customer name and password. In this configuration lacks the activation of a single ip http server to the internal LAN.
I can not connect to http. but I'm fine even if you give me the string to be writtenusing putty. thanks guys
ASA Version 8.0(4)
hostname pix2fond
domain-name onsitesrl.local
enable password ----- encrypted
passwd ----- encrypted
names
interface Vlan1
description Interfaccia INSIDE
nameif inside
security-level 100
ip address 10.51.63.161 255.255.255.192
interface Vlan2
description Interfaccia OUTSIDE
nameif outside
security-level 0
ip address 172.16.13.2 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
access-list outside extended permit icmp any any echo
access-list outside extended permit icmp any any echo-reply
access-list 101 extended permit ip 10.51.63.128 255.255.255.192 192.168.2.0 255.255.255.248
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool ip-** 192.168.2.1-192.168.2.5
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0
access-group outside in interface outside
route outside 0.0.0.0 0.0.0.0 172.16.13.2 1
route inside 10.0.0.0 255.0.0.0 10.51.63.130 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
no snmp-server location
no snmp-server contact
crypto ipsec transform-set TRANSFVPNmd5 esp-des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map MAPDYN 10 set transform-set TRANSFVPNmd5
crypto dynamic-map MAPDYN 10 set security-association lifetime seconds 28800
crypto dynamic-map MAPDYN 10 set security-association lifetime kilobytes 4608000
crypto dynamic-map dyn1 1 set transform-set TRANSFVPNmd5
crypto dynamic-map dyn1 1 set security-association lifetime seconds 28800
crypto dynamic-map dyn1 1 set security-association lifetime kilobytes 4608000
crypto map CRYPTOSITE 10 ipsec-isakmp dynamic MAPDYN
crypto map CRYPTOSITE 65535 ipsec-isakmp dynamic dyn1
crypto map CRYPTOSITE interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 65535
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 inside
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
ssh version 2
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
group-policy ** internal
group-policy ** attributes
dns-server value 213.92.5.54
vpn-idle-timeout 30
split-tunnel-policy tunnelspecified
split-tunnel-network-list value 101
username onsite password ------- encrypted
username ** password ------- encrypted
tunnel-group ** type remote-access
tunnel-group ** general-attributes
address-pool ip-**
default-group-policy **
tunnel-group ** ipsec-attributes
pre-shared-key *
tunnel-group ----- type remote-access
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect pptp
  inspect http
service-policy global_policy global
prompt hostname context
Cryptochecksum:5677ed1769676398cbb25a79027cda22
: end
Julio Carvajal Fri, 05/18/2012 - 22:34
  • Purple, 4500 points or more
Hello Davide,
From what I can understand you want to be able to access the ASA from the internal network using the GUI (ASDM)
For that you will need:
1- Have the HTTP server running on the ASA
2- Have an ASDM image on the flash of your ASA ( You can get one from cisco.com)
3- Set the ASDM image so the users can connect to the ASA
3-Decide on the HTTP server configuration who can access the ASA using HTTPS
So:
1- http server enable
2- on the sh flash  you should see an asdm image ( Show flash)
3- Set the ASDM image into your ASA ( asdm image flash:xxxxxx.img
4-http 0 0 inside ( anyone can access the HTTP service on the Inside LAN, you can be as restrictive as you want)
If this does not fixs it provide me the following:
sh run http
sh run asdm
sh flash
sh version
sh run aaa
Julio
Do rate all the helpful posts
nonsocosamettere86 Sat, 05/19/2012 - 03:44
Hello Julio,
I copy you on Monday the results of the commands you told me because all the steps you mentioned I have done. The asdm image is set but in my opinion can not find the file in flash and so must be recharged. But since they do not know, I stopped and asked for info to you before creating damage.
thanks.
hello
David
Julio Carvajal Sat, 05/19/2012 - 12:07
Sure just let me know!
Please rate all the helpful posts
ju_mobile Sun, 05/20/2012 - 15:05
The ASDM image in general would be a .bin file as Julio has directed.
nonsocosamettere86 Sun, 05/20/2012 - 23:22
asdm image is there, but not charged, in my opinion. However, an alternative would be enough for me to help me to write commands with putty ...
Saurabh Kishore Mon, 05/21/2012 - 00:19
The asdm version set in the config is 5.2.3
The software version you are running is 8.0.4, which only supports version 6.0.x or higher. ASDM 5.2.3 will not work.
So upgrade your asdm image to the latest which is 6.4.7 via TFTP
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008067e9f9.shtml#maintask2
change that in the config by the command:
asdm image flash:/asdm-647.bin
enable the http server
http server enable
Also allow the network subnet which is allowed to access the asdm by the command:
http x.x.x.x y.y.y.y  (x.x.x.x is the network and y.y.y.y is the subnet mask)
None of this is done is your config. Once you do this you should be all set without any issues.
I hope you should not have any questions after this.
nonsocosamettere86 Mon, 05/21/2012 - 01:02
I can not download the update file dell'asdm because I am not a dealer and I have no cisco certification. I did not sell me the firewall to the customer, I've found there. No one can pass the updated version of asdm?
