Ping between a real windows7 /XP PC and virtual router in GNS3
May 18th, 2012
Dear All,
In spite of giving much effort in making successful ping  between a real windows7 pc and virtual router in GNS3 Topology,I became  unsuccessful to do it.
steps followed:-
1.windows firewall disabled.NO antivirus running.
2.microsoft loopback adapter added (ip-192.168.1.10/24,gw-192.168.1.1)
3.router added in gns3 and configured (ip in interface fa0/0-192.168.1.1/24,no shut given)
4.cloud added and its loopback added to router fa0/0 interface
It is tried for window7 and xp machine.
Kindly help me resolve the problem.
Thanking you.
johnlloyd_13 Fri, 05/18/2012 - 21:39
Kindly post your running config and ipconfig/all from your PC. Make sure you've disabled your wireless adapter coz most of the time it uses the same private IP subnet messes the connectivity.
nishith_samanta2000 Mon, 05/21/2012 - 03:43
Dear Friend,
Thank u for ur response.
Please find below ipconfig/all output from my PC.
C:\Users\NOC1>ipconfig/all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : NOC-HP
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 2:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Microsoft Loopback Adapter
   Physical Address. . . . . . . . . : 02-00-4C-4F-4F-50
   DHCP Enabled. . . . . . . . . . . : No
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::6d16:38a9:a528:1224%32(Preferred)
   IPv4 Address. . . . . . . . . . . : 9.0.0.9(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . :
   DHCPv6 IAID . . . . . . . . . . . : 671219788
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-14-C7-C8-88-6C-62-6D-8F-2A-2C
   DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physical Address. . . . . . . . . : 6C-62-6D-8F-2A-2C
   Link-local IPv6 Address . . . . . : fe80::4466:7e11:d9c3:f6bc%12(Preferred)
   IPv4 Address. . . . . . . . . . . : 10.129.7.235(Preferred)
   Default Gateway . . . . . . . . . : 10.129.7.1
   DHCPv6 IAID . . . . . . . . . . . : 275538541
   DNS Servers . . . . . . . . . . . : 218.248.240.208
                                       218.248.255.177
                                       10.129.20.211
                                       10.129.20.212
                                       4.4.4.4
                                       8.8.8.8
Tunnel adapter isatap.{2C322AA8-6ABF-4168-80DD-1EBC5E7B7864}:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter 6TO4 Adapter:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
   IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:14e4:39b2:f57e:f814(Preferred)
   Link-local IPv6 Address . . . . . : fe80::14e4:39b2:f57e:f814%30(Preferred)
   NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{2A0064A7-9C27-4616-A566-8EAE63601C71}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter Reusable Microsoft 6To4 Adapter:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #2
   IPv6 Address. . . . . . . . . . . : 2002:900:9::900:9(Preferred)
   Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
C:\Users\NOC1>
And also find below sh run output from virtual router--
R1#sh run
R1#sh run
Building configuration...
Current configuration : 804 bytes
version 12.2
hostname R1
logging queue-limit 100
ip subnet-zero
no ip domain lookup
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
interface FastEthernet0/0
ip address 9.0.0.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no ip http server
no ip http secure-server
ip classless
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
end
R1#
Thanking u all.
johnlloyd_13 Mon, 05/21/2012 - 04:04
You forgot to manually add the default gateway: 9.0.0.1 on your PC.
nishith_samanta2000 Mon, 05/21/2012 - 04:27
I added default gateway 9.0.0.1 but still not working.
   Default Gateway . . . . . . . . . : 9.0.0.1
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
                                       218.248.255.177
                                       10.129.20.211
                                       10.129.20.212
                                       4.4.4.4
                                       8.8.8.8
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
C:\Users\NOC1>
Thanking You.
cadet alain Mon, 05/21/2012 - 05:27
I don't see any loopback adapter in your ipconfig output.
Regards.
Alain
nishith_samanta2000 Mon, 05/21/2012 - 05:53
Here is the loopback adapter:-
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
cadet alain Mon, 05/21/2012 - 06:16
ok I missed it but then how come the addressing is different from this ? :
Regards.
Alain
johnlloyd_13 Mon, 05/21/2012 - 06:36
Further adding to Alain's comment, could you post your router's show ip interface brief and show ip arp.
Make sure you've selected the MS loopback adapter in GNS3 cloud.
Nandan Mathure Mon, 05/21/2012 - 06:57
Hi Nishith,
As John asked, also paste the screeshot of Cloud Configuration like NIO Ethernet.
Nandan
nishith_samanta2000 Mon, 05/21/2012 - 08:12
R1#sh ip int br
R1#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            9.0.0.1         YES NVRAM  up                    up
FastEthernet0/1            unassigned      YES NVRAM  administratively down down
Virtual-Access1            unassigned      YES unset  up                    up
R1#sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  9.0.0.9                21   0200.4c4f.4f50  ARPA   FastEthernet0/0
Internet  9.0.0.1                 -   c400.25c8.0000  ARPA   FastEthernet0/0
R1#sh run
Current configuration : 811 bytes
version 12.2
hostname R1
ip subnet-zero
no ip domain lookup
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip http server
ip classless
call rsvp-sync
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
R1#
notice MS loopback adapter has been selected in GNS3 cloud.
Nandan Mathure Mon, 05/21/2012 - 09:20
I recreated this on my PC works without any issues:
1] I added MS-Loopback , assigned IP statically IP :10.10.10.10 MASK : 255.255.255.0 GW:10.10.10.1
2] Restarted the PC
3] In GN3 i assigned the MS-Loopback to cloud.
4] Connected the Router to the Cloud with Fa0/0
5] Router Fa0/0 IP: 10.10.10.1 Mask 255.255.255.0
6] Ping from Router to PC = Success
7] Ping from PC to Router = Success
I tested this on XP machine. If its still not working, then delete the loopback, recreate step by step and let us know if it works.
Nandan
cadet alain Mon, 05/21/2012 - 23:02
if you shutdown/ no shutdown the f0/0 on R1 is the ping working now ?
Regards.
Alain
Nandan Mathure Mon, 05/21/2012 - 23:40
Hi Nishith,
Could you post the output for "debug ip icmp" and "debug ip packet detail" when you start pinging from PC to ROUTER and ROUTER to PC ?
Nandan Mathure
nishith_samanta2000 Tue, 05/22/2012 - 00:16
Hi Nandan,
R1#debug ip icmp
ICMP packet debugging is on
R1#ping 10.10.10.10
Sending 5, 100-byte ICMP Echos to 10.10.10.10, timeout is 2 seconds:
Success rate is 0 percent (0/5)
R1#
R1#debug ip packet detail
IP packet debugging is on (detailed)
R1#ping 10.10.10.10
*Mar  1 01:07:33.551: IP: s=10.10.10.1 (local), d=10.10.10.10 (FastEthernet0/1), len 100, sending
*Mar  1 01:07:33.555:     ICMP type=8, code=0.
*Mar  1 01:07:35.551: IP: s=10.10.10.1 (local), d=10.10.10.10 (FastEthernet0/1), len 100, sending
*Mar  1 01:07:35.551:     ICMP type=8, code=0.
*Mar  1 01:07:37.551: IP: s=10.10.10.1 (local), d=10.10.10.10 (FastEthernet0/1), len 100, sending
*Mar  1 01:07:37.551:     ICMP type=8, code=0.
*Mar  1 01:07:39.551: IP: s=10.10.10.1 (local), d=10.10.10.10 (FastEthernet0/1), len 100, sending
*Mar  1 01:07:39.551:     ICMP type=8, code=0.
*Mar  1 01:07:41.551: IP: s=10.10.10.1 (local), d=10.10.10.10 (FastEthernet0/1), len 100, sending
*Mar  1 01:07:41.551:     ICMP type=8, code=0.
R1#
Nishith
cadet alain Tue, 05/22/2012 - 01:04
isn't your loopback 9.0.0.9 ? so why not pinging this first ?
Can you do this with the windows firewall turned off and also do the debug again as well as sniff your loopback on Windows
and the f0/0 interface on GNS3 with wireshark.
Regards.
Alain
nishith_samanta2000 Tue, 05/22/2012 - 02:22
hello alain,my current loopback ip-10.10.10.10/24,gw-10.10.10.1
router ip-10.10.10.1/24
PLS find below packet capture on loopback interface:-
notice in we see reply from pc but not from router.
but actually I cant see any reply in both direction
cadet alain Tue, 05/22/2012 - 02:48
When you ping from loopback to router what is telling the debug ip icmp on the router ?
Regards.
Alain
johnlloyd_13 Tue, 05/22/2012 - 05:12
hi,
can you post a screenshot of your network info and setup? go to control panel > network and internet > network and sharing center. as suggested previously, make sure you've temporarily disabled other NICs (especially wifi) and select the proper network (i use mine as home network/group) for the MS loopback NIC/network.
http://windows.microsoft.com/en-us/windows7/Choosing-a-network-location
nishith_samanta2000 Mon, 05/28/2012 - 20:35
Dear All,
It is now pinging.the problem was with the rouge image.After i changed the it just worked fine.
