Warning message
How to set a maximum download size per connection in the ASA?
Answered Question
May 21st, 2012
Hi, I would like to avoid big downloads so I want to set a maximum download file size. How can I set the limit MB allowed per connection in the ASA?
Correct Answer by Julio Carvajal about 5 years 2 months ago
Yes, you will be able to do that using the Modular Policy Framework (MPF)
access-list test permit tcp host x.x.x.x host y.y.y.y eq 80
class-map test
match access-list test
policy-map global_policy
class test
set connection timeout x.x.
Julio
Overall Rating: 4.2 (6 ratings)
Julio Carvajal Mon, 05/21/2012 - 10:06
  • Purple, 4500 points or more
Hello Jmprats,
Being honest to you I know we can configure timeouts for particular connections or the maximun amount of connections per host.
We can also configure the maximum bandwitht that a particular traffic pattern can have but I am almost sure there is no option to limit a connection based on the download size of a connection ( ASA speaking)
Julio
jmprats Tue, 05/22/2012 - 03:18
So, I suppose I will have to work with connections timeouts. Can I set different timeouts for differents source ip address?
Correct Answer
Julio Carvajal Tue, 05/22/2012 - 09:46
class-map test
class test
Julio
Andrew Phirsov Wed, 03/06/2013 - 09:54
  • Silver, 250 points or more
Is it possible to set connection tieout in the newer versions (ie 8.4, 9.1)? Not idle or tcp-embriotic or smth, but timeout for regular legitimate connections. Just as on example in previos post. In newer version i don't see such option. Any clue?
jocamare Wed, 03/06/2013 - 10:02
Are we talking about a "timeout" for normal and working connections?
The function of the current timeouts is to free resources on the unit and provide protection.
Andrew Phirsov Wed, 03/06/2013 - 10:16
I'm not sure u answered my question. Look at previos post by jcarvaja. See the commands? (particulary
set connection timeout x.x.). Is there a way to achieve this in newer versions. I.e. not set conection timeout idle/half-open/embriotic, but just set connection timeout without any other keywords.
Julio Carvajal Wed, 03/06/2013 - 10:19
Hello Andrew,
I got your question, but I think we might be confused here, I did not specify something after the timeout but when you configure it you will see you have the same options
Here is the configuration options on 8.2.5
ciscoasa(config-pmap-c)# set connection timeout ?
mpf-policy-map-class mode commands/options:
  dcd          Configure dead-connection-detection retry interval.
  embryonic    Configure absolute time after which an embryonic TCP connection
               will be closed, default is 0:00:30.
  half-closed  Configure idle time after which a TCP half-closed connection
               will be freed, default is 0:10:00
  idle         Configure idle time after which a connection state will be
               closed.
Now on an ASA running 8.4.4(9)
WPLG-ASA-1(config-pmap-c)# set connection timeout ?
               closed.
So as you can see same options, no change at all
Hope that I could help
Remember to rate all of the helpful posts
Andrew Phirsov Wed, 03/06/2013 - 10:40
I always thought that it was possible to generaly limit conn timeout for specific set of traffic (), but, as it turned out it can't be done. Interesting)
jmprats Tue, 03/12/2013 - 04:39
And back to the original question. Is there any way to monitor who is uploading or downloading?
I can monitor connection MBytes, but I cannot see which direction they are (upload or download).
Julio Carvajal Sat, 03/16/2013 - 13:37
Why dont you use Netflow on the ASA...
Of course you will need a software to be able to understand the netflow traffic from the ASA ( Records and templates), I would even recommend you to go with the PRTG software, a beauty that is for free ( just to 1 to 10 devices) and it will show you that stuff
Go ahead and get PRTG and enable SNMP on the ASA,
Cheers mate
Julio Carvajal Segura
Related Content
