Warning message
Cisco UCS start VMwares Automatically when down
Answered Question
May 21st, 2012
I have an incident that one of our customer's UCS server C200 M2 has been down due to power failure. Since the customer location is too far out of the city it takes us some while to get there to run all the Vmwares (CUCM Pub,CUCM Sub, CUC) to work again manually using vsphere client .
I was wondering is there any configuration need to be done that when the UCS is getting started it automatically start all the hosted vmwares ?
Amr Sherif
Correct Answer by Aaron Harrison about 5 years 3 months ago
vSphere is the client application that you use to administer VMware hosts. This has settings for automatic machine start/shutdown in the 'configuration' tab and it is the only way that you will get the setting enabled.
This applies to UCS or any other platform that runs VMware.
Aaron
Correct Answer by Chris Deren about 5 years 3 months ago
Sure, configure automatic start/shut for all VMs in the vSphere client.
HTH,
Chris
Overall Rating: 5 (2 ratings)
Correct Answer
Chris Deren Mon, 05/21/2012 - 06:24
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
asherif82 Tue, 05/22/2012 - 01:58
Hi Chris,
I dont want to get in touch with vshphere, Just when power on the UCS chassis ,it automatically make the vmware station to work.
Amr Sherif
Correct Answer
Aaron Harrison Tue, 05/22/2012 - 02:08
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
