UCCX 8.0.2 Installation error?
May 21st, 2012
Hello All,
I'm trying to install UCCX 8.0.2  Installation on VMware Infrastrcture in the Lab environment.
Enclosed file is the screen shot of Installation error, I appreciate if you can advise me why I'm facing this installation error?
anchoudh Mon, 05/21/2012 - 06:57
  • Red, 2250 points or more
hi Suryanarayana Chintu,
Press Alt + F2 and collect the logs under cd/tmp.
Insert the recovery cd , boot and copy log files from /mnt/part6/log/
Need to see these logs to tell you which RPM has encountered an issue during the install.
Hope it helps.
Anand
Pls rate helpful posts !!
