ASDM - PIX Config Help
Answered Question
May 21st, 2012
I am trying to veiw my PIX515e via the ASDM, but I am unable to...Can you review my config and make sure I have everything setup the way it is supposed to?
PIX Version 8.0(4)32
hostname pixfirewall
domain-name jkkcc.com
enable password DQucN59Njn0OjpJL encrypted
passwd DQucN59Njn0OjpJL encrypted
no names
interface Ethernet0
nameif outside
security-level 0
ip address 24.234.xxx.xxx 255.255.255.224
interface Ethernet1
nameif inside
security-level 100
ip address 10.0.20.1 255.255.255.248
interface Ethernet2
shutdown
nameif exchange
security-level 100
ip address 10.0.30.1 255.255.255.248
ftp mode passive
dns domain-lookup inside
dns server-group DefaultDNS
name-server 68.105.28.16
name-server 68.105.29.16
access-list ouside-acl extended permit tcp any host 24.234.xxx.xxx eq smtp
access-list ouside-acl extended permit tcp any host 24.234.xxx.xxx eq www
access-list ouside-acl extended permit tcp any host 24.234.xxx.xxxeq https
pager lines 24
mtu outside 1500
mtu inside 1500
mtu exchange 1500
icmp unreachable rate-limit 1 burst-size 1
icmp deny any outside
asdm image flash:/asdm-602.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface smtp 192.168.2.22 smtp netmask 255.255.255.255
static (inside,outside) tcp interface https 192.168.2.22 https netmask 255.255.255.255
static (inside,outside) tcp interface www 192.168.2.22 www netmask 255.255.255.255
access-group ouside-acl in interface outside
router eigrp 1
network 10.0.0.0 255.0.0.0
network 192.168.0.0 255.255.255.0
network 192.168.2.0 255.255.255.0
network 192.168.4.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 24.234.118.193 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
http server enable
http 0.0.0.0 0.0.0.0 inside
http 10.0.20.0 255.255.255.248 inside
http 192.168.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community *****
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect http
  inspect ils
service-policy global_policy global
prompt hostname context
Cryptochecksum:abd41b3df257873d44a6fc1545ae4418
: end
Correct Answer by Julio Carvajal about 5 years 5 days ago
Hello Jonathan,
Please close this treath as you already open another one ( duplicate) or just mark it as answered.
Julio
Overall Rating: 5 (1 ratings)
Correct Answer
Julio Carvajal Mon, 05/21/2012 - 20:24
  • Purple, 4500 points or more
Hello Jonathan,
Julio
Related Content
