Network Design
Answered Question
May 22nd, 2012
Hello
I have been told to setup a network with proper security and QOS. The Setup includes
Head Office with 200 users
25 Branch offices connecting to HO with local telecom MPLS Cloud
20 International Branches connecting to HO over VPN
Video Conferencing with good Quality
Ensure having Redundant Internet link  < 2 Internet Provider >
Decent Internet surfing speed with restriction to social networking sites
Hosting services at HO
  1. Centralized Mail services
  2. Centralized ERP Application
  3. Centralized Portal Hosting - Sharepoint
  4. Windows Server, DNS,DHCP
National Branch office should get IP address from HO
International Branch Office should contain
  1. Windows DHCP,DNS
  2. Internet Browsing Traffic from local provider
Available devices in HO
4507 series L3 Switch with 24 port SFP module + 48port 10/100/100 Ethernet module
3845 series Router X 2
2960 switches X 10
ASA 5520
  • Will the 4507 sufficient enough as BackBone Switch.
  • Can VPN and MPLS service be enabled on same router? Is this recommended
what more hardware we would need and how to terminate both Internet links. The placement of MPLS router, VPN device on the network
cheers
Steve
Correct Answer by Tagir Temirgaliyev about 5 years 10 hours ago
1. For Kiwi syslog any specific setup in needed or follow the installation guide.
2. kiwi syslog is freeware i assume.
there is kiwi syslog freeware and  not too
3.the configuration you posted will display all failed and passed   only or more information.
all attempts
dont forget to rate post
Correct Answer by Leo Laohoo about 5 years 4 days ago
13MB Internet Bandwidth in HO, do  we need to buy additional hardware to gurantee dedicated bandwidth for different services, not sure if qos can gurantee bandwidth incomming / outgoing.
3845 can push 13 Mbps of traffic without breaking a sweat.
planning to connect Servers, switches, routers to 4507
Ok, so I presume you're going to be using 1 Gbps or 10 Gbps?  I wouldn't recommend plain 4507.  Look at 4507R+E and Sup7E (not Sup7LE).
Overall Rating: 5 (4 ratings)
Leo Laohoo Tue, 05/22/2012 - 15:27
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
What is the bandwidth of the HO?
Depends on what's connected to the switch?  What are the uplinks?
Devavrat Oka Wed, 05/23/2012 - 13:26
I would recommend having two ASAs for active/passive failover. Use the 3845 routers to peer with remote offices over MPLS. Use BGP for this.
Run an internal routing protocol (EIGRP) between 4507 and ASAs. 4507 is the CORE. If possible, use a second 4507 as redundant CORE.
Use the 2960s as Access switches. If possible, stack them. Run port-channel up to the CORE from these Access switches.
As far as the International offices are concerned, you can terminate the VPN on the routers (3845) or use the outside interface on the ASA (which is not what I would do). The ASAs running failover would share the active outside IP address, which would be the peer for the VPN tunnel. In case of a failover, switching between ASA roles would cause a timeout and break the VPN tunnel. Hence terminate on 3845s.
joseph.steve Thu, 05/24/2012 - 00:28
Hello leolaohoo
  1. 13MB Internet Bandwidth in HO, do  we need to buy additional hardware to gurantee dedicated bandwidth for different services, not sure if qos can gurantee bandwidth incomming / outgoing.
2.     planning to connect Servers, switches, routers to 4507
Hello Oka
thank you for kind feedback.
Not clear to run DHCP on Router or Windows Server.
Can National branch office get ip from Central DHCP Server (HO)
Can you advice on tool for Monitoring network devices, alert on config changes, auto config backup weekly or on config change.
Tool to get all logs for passed or failed attempts accessing network devices
Correct Answer
Leo Laohoo Thu, 05/24/2012 - 04:14
  • Hall of Fame,
    2017 LAN, Wireless
Tagir Temirgaliyev Thu, 05/24/2012 - 23:08
  • Silver, 250 points or more
1. Tool to get all logs for passed or failed attempts accessing network devices
for example kiwi syslog installed on pc with address a.b.c.d
on each cisco network devices
en
conf t
logging message-counter syslog
logging buffered 100000
logging buffered debbug
logging a.b.c.d
access-list 23 permit any log
line vty 0 4
access-class 23 in
wr
so each telnet attepts will be logged in syslog
2. Can you advice on tool for Monitoring network devices,
try mrtg
3. alert on config changes, auto config backup weekly or on config change.
Cisco ACS
joseph.steve Fri, 05/25/2012 - 05:32
Hello leolaohoo - thanks for sharing your experience.  what is difference between SUP 7E  against SUP 7LE.
can you ellaborate more on QOS
Hello ttemirgaliyev -  For Kiwi syslog any specific setup in needed or follow the installation guide. kiwi syslog is freeware i assume. the configuration you posted will display all failed and passed attempt only or more information.
Correct Answer
Tagir Temirgaliyev Sun, 05/27/2012 - 19:52
all attempts
Leo Laohoo Tue, 05/29/2012 - 15:12
  • Hall of Fame,
    2017 LAN, Wireless
I haven't used the Sup7LE but all I can determine is that the Sup7LE is the "dumb down" version of the Sup7E.  The "L" stands for LITE.  The Sup7LE has a lower switching throughput, for example.
Check out the comparison table between the two supervisor cards from here.   Click the "Supervisor" tab.
Devavrat Oka Tue, 05/29/2012 - 10:49
It is recommended you run DHCP on a windows server or a linux host. The reason being less CPU utlization on a cisco device if you lease time is less and you have a lot of DHCP clients. Other reason is DHCP would have to rely on the network performance. If you lose a certain link that goes up to your DHCP server (cisco device), your clients would not be able to reach out to the DHCP server (no DHCP ACK).
Yes remote offices can get DHCP from a Head Office but again, not recommended to have DHCP go over WAN.
Use solar winds orion as a netmon tool.
Like others have suggested, use kiwi log.
