Cisco ASA 8.4(3) Remote Access VPN - client connects but cannot access inside network
Answered Question
May 22nd, 2012
                   I am having issues accessing resources on the inside network when connecting with Cisco client VPN to a Cisco ASA 5510 running 8.4(3) version of the IOS. I have tried all of the new 8.4 NAT commands but cannot access the inside network. I can see traffic in the logs when pinging. I can only assume I have the NAT wrong or it is because the inside interface of the ASA is on the same /24 subnet as the inside network?? Please see config below, any suggestions would be appreciated. I have configured a site to site VPN to this same 5510 and it is running fine
interface Ethernet0/0
speed 100
duplex full
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.240
interface Ethernet0/1
speed 100
duplex full
nameif inside
security-level 100
ip address 10.88.10.254 255.255.255.0
interface Management0/0
shutdown
nameif management
security-level 0
no ip address
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network PAT_to_Outside_ClassA
subnet 10.88.0.0 255.255.0.0
object network PAT_to_Outside_ClassB
subnet 172.16.0.0 255.240.0.0
object network PAT_to_Outside_ClassC
subnet 192.168.0.0 255.255.240.0
object network LocalNetwork
object network RemoteNetwork1
subnet 192.168.0.0 255.255.0.0
object network RemoteNetwork2
subnet 172.16.10.0 255.255.255.0
object network RemoteNetwork3
subnet 10.86.0.0 255.255.0.0
object network RemoteNetwork4
subnet 10.250.1.0 255.255.255.0
object network NatExempt
subnet 10.88.10.0 255.255.255.0
object-group network Site_to_SiteVPN1
network-object 192.168.4.0 255.255.254.0
network-object 172.16.10.0 255.255.255.0
network-object 10.0.0.0 255.0.0.0
access-list outside_access_in extended deny ip any any
access-list inside_access_in extended permit ip any any
access-list 11 extended permit ip 10.250.1.0 255.255.255.0 any
access-list outside_1_cryptomap extended permit ip 10.88.0.0 255.255.0.0 object-group Site_to_SiteVPN1
ip local pool Admin_Pool 10.250.1.1-10.250.1.254 mask 255.255.255.0
nat (inside,outside) source static NatExempt NatExempt
nat (inside,outside) source static any any destination static RemoteNetwork4 RemoteNetwork4 route-lookup
nat (inside,outside) source static LocalNetwork LocalNetwork destination static RemoteNetwork1 RemoteNetwork1
nat (inside,outside) source static LocalNetwork LocalNetwork destination static RemoteNetwork2 RemoteNetwork2
nat (inside,outside) source static LocalNetwork LocalNetwork destination static RemoteNetwork3 RemoteNetwork3
nat (inside,outside) source static LocalNetwork LocalNetwork destination static RemoteNetwork4 RemoteNetwork4 route-lookup
nat (inside,outside) dynamic interface
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
dynamic-access-policy-record DfltAccessPolicy
sysopt connection timewait
service resetoutside
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set bh-set esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10 set pfs
crypto dynamic-map dynmap 10 set ikev1 transform-set bh-set
crypto dynamic-map dynmap 10 set security-association lifetime seconds 28800
crypto dynamic-map dynmap 10 set security-association lifetime kilobytes 4608000
crypto dynamic-map dynmap 10 set reverse-route
crypto map mymap 1 match address outside_1_cryptomap
crypto map mymap 1 set peer x.x.x.x
crypto map mymap 1 set ikev1 transform-set ESP-AES-256-SHA
crypto map mymap 1 set security-association lifetime seconds 86400
crypto map mymap 1 set security-association lifetime kilobytes 4608000
crypto map mymap 100 ipsec-isakmp dynamic dynmap
crypto map mymap interface outside
crypto isakmp identity address
crypto isakmp nat-traversal 30
crypto ikev1 enable outside
crypto ikev1 ipsec-over-tcp port 10000
crypto ikev1 policy 5
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 10
encryption 3des
hash sha
group 1
lifetime 86400
crypto ikev1 policy 50
encryption des
hash md5
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes-256
hash sha
group 1
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
telnet timeout 5
console timeout 0
management-access inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy BACKDOORVPN internal
group-policy BACKDOORVPN attributes
vpn-filter value 11
vpn-tunnel-protocol ikev1
split-tunnel-policy tunnelall
default-domain value bh.uk
tunnel-group BACKDOORVPN type remote-access
tunnel-group BACKDOORVPN general-attributes
address-pool Admin_Pool
default-group-policy BACKDOORVPN
tunnel-group BACKDOORVPN ipsec-attributes
ikev1 pre-shared-key *****
tunnel-group x.x.x.x type ipsec-l2l
tunnel-group x.x.x.x ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
Correct Answer by rizwanr74 about 5 years 3 days ago
excellent.
Please rate helpful post.
thanks
Rizwan Rafeek
Overall Rating: 5 (1 ratings)
rizwanr74 Tue, 05/22/2012 - 07:31
  • Gold, 750 points or more
Hi Matt,
If you are running a L3 switch behind your ASA, please make sure that you have a static-route in place to push "10.250.1.0/24 " to 10.88.10.254.
Please let me know, if this helps.
Rizwan Rafeek
Kevin P Sheahan Tue, 05/22/2012 - 07:31
  • Bronze, 100 points or more
New ASA code is buggy with 'any any' on NATs.
Try changing....
To
nat(inside,outside) source static RemoteNetwork4 RemoteNetwork4 static LocalNetwork LocalNetwork route-lookup
Kind Regards,
Kevin
**Please remember to rate helpful posts as well as mark the question as 'answered' once your issue is resolved. This will help others to find your solution faster.
mattr1973 Tue, 05/22/2012 - 08:36
Thanks Rizwan - the L3 switch default gateway is 10.88.10.254....but good to double check
Kevin - thanks for your reply also. I have now changed the NAT config to the below as you suggested;
nat (inside,outside) source static RemoteNetwork4 RemoteNetwork4 destination static LocalNetwork LocalNetwork route-lookup
I then ran a telnet from remote client to inside host on port 80 - this is what I got in the ASA logs;
May 22 2012 16:28:15: %ASA-5-305013: Asymmetric NAT rules matched for forward and reverse flows; Connection for tcp src outside:10.250.1.1/53229(LOCAL\mrichards) dst inside:10.88.10.11/80 denied due to NAT reverse path failure
May 22 2012 16:28:15: %ASA-7-710005: UDP request discarded from 10.250.1.1/51022 to outside:224.0.0.252/5355
May 22 2012 16:28:18: %ASA-5-305013: Asymmetric NAT rules matched for forward and reverse flows; Connection for tcp src outside:10.250.1.1/53229(LOCAL\mrichards) dst inside:10.88.10.11/80 denied due to NAT reverse path failure
rizwanr74 Tue, 05/22/2012 - 09:29
Hi Matt,
Please post the output from below traceroute.
packet-tracer input outside icmp 10.250.1.2 8 0 10.88.10.2
If you do see the passthrough in every stage in the output from above, then you most likely missing a route on your ASA.
So, please add a static-route on your ACL as shown below.
route inside 10.88.0.0 255.255.0.0 10.88.10.x  <--- x = your L3 switch's ip address which is connected to ASA.
FYI...
Your orignal no-nat your have had configured is fine with me, there is no need to change it.
Please update.
thanks.
Rizwan Rafeek
Message was edited by: Rizwan Mohamed
mattr1973 Wed, 05/23/2012 - 02:37
Hi Rizwan
Please see output from packet trace - getting dropped by outside interface ACL;
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.88.10.0      255.255.255.0   inside
Phase: 3
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
NAT divert to egress interface inside
Untranslate 10.88.10.2/0 to 10.88.10.2/0
Phase: 4
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         outside
Phase: 5
Type: ACCESS-LIST
Subtype: log
Result: DROP
Config:
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Here is the configured NAT on the ASA;
The configured PAT;
And the routing table;
C    x.x.x.x 255.255.255.240 is directly connected, outside
C    10.88.10.0 255.255.255.0 is directly connected, inside
S*   0.0.0.0 0.0.0.0 [1/0] via x.x.x.x, outside
mattr1973 Wed, 05/23/2012 - 06:16
Thanks for your response, however the intercept-dhcp enable command did not resolve the issue
When connected with the VPN client and running a ping from VPN host to inside network host, I get the following in the ASA logs but I do not get reply;
May 23 2012 14:12:00: %ASA-6-302020: Built inbound ICMP connection for faddr 10.250.1.1/1(LOCAL\mrichards) gaddr 10.88.10.250/0 laddr 10.88.10.250/0 (mrichards)
May 23 2012 14:12:00: %ASA-6-302020: Built outbound ICMP connection for faddr 10.250.1.1/1(LOCAL\mrichards) gaddr 10.88.10.250/0 laddr 10.88.10.250/0
May 23 2012 14:12:02: %ASA-6-302021: Teardown ICMP connection for faddr 10.250.1.1/1(LOCAL\mrichards) gaddr 10.88.10.250/0 laddr 10.88.10.250/0 (mrichards)
rizwanr74 Wed, 05/23/2012 - 07:20
Hi Matt,
Please remote the highlighted line in the no-nat statement below "route-lookup"
Please let me know.
mattr1973 Wed, 05/23/2012 - 09:17
Guys....it is working now....thanks for all your comments
The original site to site object group (SIte-to_SiteVPN1) was causing the issue as I had the full class A subnet specified for the site to site tunnel
I changed this object group to;
network-object 10.86.0.0 255.255.0.0
network-object 10.87.0.0 255.255.0.0
And it is working now.....
Thanks again!
Correct Answer
rizwanr74 Wed, 05/23/2012 - 09:43
excellent.
thanks
Rizwan Rafeek
Related Content
