Warning message
FTP not working behind firewall
I've currently got a Cisco 891 running with a FTP server behind it. All FTP clients running inside the network can use the FTP by going directly to the internal IP of 192.168.12.6. However all outside clients are getting a connection to the server but then dropping. I've got NAT configured to go from external IP on port 990 to internal IP address 192.168.12.6 on port 990. The FTP is listening on port 990. The clients can only run in passive mode.
Below is the version information and current running config.... Any help would be greatly appreciated.... Ignore the NAT going to internal IP 192.168.12.50, it's for another operation.
Cisco IOS Software, C890 Software (C890-UNIVERSALK9-M), Version 15.0(1)M6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 01-Jun-11 21:24 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB3, RELEASE SOFTWARE (fc1)
yourname uptime is 6 minutes
System returned to ROM by reload at 11:04:09 PCTime Tue May 22 2012
System restarted at 11:04:35 PCTime Tue May 22 2012
System image file is "flash:c890-universalk9-mz.150-1.M6.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
Building configuration...
Current configuration : 11614 bytes
! Last configuration change at 11:09:50 PCTime Tue May 22 2012 by XXXXXXXX
version 15.0
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service udp-small-servers
service tcp-small-servers
service sequence-numbers
hostname yourname
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5
ip finger
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
class-map type inspect match-any ccp-cls-protocol-p2p
match protocol edonkey signature
match protocol gnutella signature
match protocol kazaa2 signature
match protocol fasttrack signature
match protocol bittorrent signature
class-map type inspect match-all sdm-nat-user-protocol--1-1
match access-group 102
match protocol user-protocol--1
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-cls-protocol-im
match protocol ymsgr yahoo-servers
match protocol msnmsgr msn-servers
match protocol aol aol-servers
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
class-map type inspect match-all sdm-nat-ftp-1
match access-group 101
match protocol ftps
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
inspect
class class-default
pass
policy-map type inspect sdm-pol-NATOutsideToInside-1
class type inspect sdm-nat-ftp-1
inspect
class type inspect sdm-nat-user-protocol--1-1
inspect
class class-default
drop
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
drop log
class type inspect ccp-protocol-http
inspect
class type inspect ccp-insp-traffic
inspect
class type inspect ccp-sip-inspect
inspect
class type inspect ccp-h323-inspect
inspect
class type inspect ccp-h323annexe-inspect
inspect
class type inspect ccp-h225ras-inspect
inspect
class type inspect ccp-h323nxg-inspect
inspect
class type inspect ccp-skinny-inspect
inspect
class class-default
drop
class class-default
drop
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-out-self source out-zone destination self
service-policy type inspect ccp-permit
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security sdm-zp-NATOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-NATOutsideToInside-1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
description $ES_WAN$$ETH-WAN$$FW_OUTSIDE$
ip address X.X.X.X 255.255.255.240
ip mask-reply
ip directed-broadcast
ip flow ingress
ip nat outside
ip virtual-reassembly
zone-member security out-zone
duplex auto
speed auto
interface GigabitEthernet0
no ip address
ip mask-reply
ip flow ingress
shutdown
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
ip mask-reply
ip flow ingress
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$$ES_LAN$$FW_INSIDE$
ip address 192.168.12.1 255.255.255.0
ip mask-reply
ip flow ingress
ip nat inside
zone-member security in-zone
ip tcp adjust-mss 1452
interface Async1
no ip address
ip mask-reply
encapsulation slip
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list 1 interface FastEthernet8 overload
ip nat inside source static tcp 192.168.12.50 2080 interface FastEthernet8 2080
ip nat inside source static tcp 192.168.12.6 990 interface FastEthernet8 990
ip route 0.0.0.0 0.0.0.0 209.60.166.193
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.12.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 100 permit ip X.X.X.X 0.0.0.15 any
access-list 101 remark CCP_ACL Category=0
access-list 101 permit ip any host 192.168.12.6
access-list 102 remark CCP_ACL Category=0
access-list 102 permit ip any host 192.168.12.50
no cdp run
