Cisco AnyConnect Secure Mobility Client Installation error
Answered Question
May 22nd, 2012
I am getting the following error when trying to install Cisco AnyConnect Secure Mobility Client on Windows XP machine.
"The VPN client agent was unable to create the client DNS plugin manager"
Any suggestions please to fix this error
banums
Correct Answer by Javier Portuguez about 4 years 10 months ago
It is always recommended to install the VPN client with the AV and 3rd party applications off to avoid conflicts.
On the other hand, if this is solved, please mark this as answered and rate any post you find helpful.
Thanks.
Portu.
Overall Rating: 5 (1 ratings)
Jennifer Halim Tue, 05/22/2012 - 19:11
  • Cisco Employee,
what version of anyconnect client are you trying to install? pls share the full file name of the software.
Also how do you install it, push from the ASA or manually installing it?
did the install finished or it does not finish installing the client? if the install is completed, can you please enable the vpnagent service from services panel.
banums Wed, 05/23/2012 - 14:19
I am trying to manually install the Cisco AnyConnect Secure Mobility Client Version 3.0.5080 on windows xp using administrator account
The Installation was not completed
hinduu123 Thu, 07/26/2012 - 19:30
Hi Banums
Any Luck with this , I am having the same issue.
_MD
banums Fri, 07/27/2012 - 07:46
Re-installation with stopping most of the processes including antivirus solved the problem
Correct Answer
Javier Portuguez Fri, 07/27/2012 - 23:33
  • Red, 2250 points or more
Thanks.
Portu.
Related Content
