Warning message
Copper Ethernet into Nexus 5548
Answered Question
May 22nd, 2012
Hello...new to the nexus world. We have a server that we would like to use on our new Nexus 5548 however, it has only Copper ethernet. Does Cisco have a copper SFP for the 5548. I know that 6500's had a copper SFP but, I'm not sure if that would be compatable in the Nexus 5548 world.
Dan
Correct Answer by Reza Sharifi about 5 years 2 months ago
Overall Rating: 5 (2 ratings)
Devavrat Oka Tue, 05/29/2012 - 10:53
Make sure you do a speed 1000 if the port is a 1gb ethernet link. Otherwise you'll see it as inactive or unknown module or something like that on the NX5K.
int ethX/X
speed 1000
Ashok Basapure Tue, 08/21/2012 - 12:48
Reza/Devavrat,
Similarly I want to connect Cisco 2811 router to NX5548UP. How should I proceed?
Ashok
Jerry Ye Tue, 08/21/2012 - 13:05
  • Cisco Employee,
Like I said in your other post, 2811 is only 10/100 and cannot connect to the 5548 directly (1000/10G only).
HTH,
jerry
Devavrat Oka Tue, 08/21/2012 - 13:13
jerry is right, the NX5548UP won't scale down 100mbps. Try using a Cisco 2900 ISR or use a Nexus 2000 FEX'd to the 5K.
Reza Sharifi Tue, 08/21/2012 - 13:17
  • Cisco Designated VIP,
    2017 LAN
If budget is an issue, you can use a 2821, but you also need a media converter to convert from copper (2800) to fiber (Nexus)
Reza Sharifi Tue, 08/21/2012 - 13:22
    2017 LAN
Yes, I like the idea of using GLC-T
+5
Leo Laohoo Tue, 08/21/2012 - 23:23
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
No need. Use a GLC-T on the 5K (copper)
But the GLC-T on a Nexus 5k will NOT negotiate to 100 Mbps, will it?
If not, then one of the solution is for a HWIC-1GE-SFP on the 2811.
Reza Sharifi Wed, 08/22/2012 - 05:45
    2017 LAN
Leo,
GLC-T would work if the device is 2821 not 2811.
2821 comes with 2 10/100/1000 on board ports.
Reza
Leo Laohoo Wed, 08/22/2012 - 16:20
  • Hall of Fame,
    2017 LAN, Wireless
Hi Reza,
But Ashok has stated that he's got the 2811.
Jerry Ye Wed, 08/22/2012 - 17:18
  • Cisco Employee,
Hi Leo,
This is why I said it cannot be done. Ashok also have a strict requirement that he will not upgrade the 2811 to anything else. The only solution is use the FEX.
jerry
Ashok Basapure Fri, 08/24/2012 - 14:22
Hello All,
Following is the summary:
At Router 2811
One port Gigabit module: HWIC-1GE-SFP
Trans receiver : GLC-T – 1 QTY
At Nexus 5548
Above requirements will enable me to connect Cisco 2811 router to Nexus 5548 switch.
Please let me know you views.
Ashok
Jerry Ye Fri, 08/24/2012 - 14:24
  • Cisco Employee,
This will work.
jerry
Devavrat Oka Fri, 08/24/2012 - 14:31
No because the 2811 goes upto a 100mb and the 5548 can come down to 1Gb.
Jerry Ye Fri, 08/24/2012 - 14:48
  • Cisco Employee,
Hi Devavrat,
Ashok said he will put a HWIC-1GE-SFP, it will work.
jerry
Related Content
