05-23-2012 02:59 AM - edited 03-01-2019 07:06 AM
Hi All
Maurice Zehnder confirmed i can route and loadbalance in 'inline' configuration
on an ACE 4710, thanks maurice !
Below i have more or less one of the configs from my ACE course , its the first time i have
really configured the ACE so you will have to bear with me.
My question is -
the below should work for ln loadbalancing between the 2 servers in the serverfarm TESTFARM
but i have another server on the vlan xx.xx.122.0/24.
Will that server be routable to ? - just want to be able to reach it not loadbalance it in any way
So i want 2 loadbalanced servers and one just accessible on the same subnet.
I have configured the following on my ACE -
access-list EVERYONE line 10 extended permit tcp any any
rserver host TEST-1
ip address xx.xx.122.1
inservice
rserver host TEST-2
ip address xx.xx.122.2
inservice
serverfarm host TESTFARM
rserver TEST-1
inservice
rserver TEST-2
inservice
class-map match-all VIP-150
2 match virtual-address xxx.xx.121.150 any
class-map type management match-any REMOTE-ACCESS
2 match protocol icmp any
3 match protocol telnet any
4 match protocol ssh any
5 match protocol https any
6 match protocol http any
7 match protocol xml-https any
policy-map type management first-match MGMT_TEST
class REMOTE-ACCESS
permit
policy-map type loadbalance first-match lb-logic
class class-default
serverfarm TESTFARM
policy-map multi-match CLIENT-VIPS
class VIP-150
loadbalance vip inservice
loadbalance policy lb-logic.
int vlan 122
des servers
ip address xx.xx.122.172 255.255.255.0
no shut
int vlan 121
ip address xx.xx.121.1 255.255.255.0
access-group input EVERYONE
service-policy input remote-mgmt
service-policy input CLIENT-VIPS
no shut
ip route 0.0.0.0 0.0.0.0 xx.xx.121.1
Steve
Solved! Go to Solution.
05-23-2012 04:33 AM
Hi Steve
Yes this will work. As long you have a route on your upstream device (router or firewall) towards the ACE for your server subnet:
"Upstream Device" ----- (interface vlan121) ACE (interface vlan 122) ---- Server
-Your server will be configured with a default gateway of xx.xx.122.172.
-You have to change de default route on the ACE (ip route 0.0.0.0 0.0.0.0 xx.xx.121.1) - At the moment the route is pointing to the IP of the ACE. Change the next hop of the route with the IP of your "upstream device"
-On your upstream device configure a route via the ACE for the server subnet eq. "ip route x.x.122 255.255.255.0 x.x.121.1"
Marcel
05-23-2012 04:33 AM
Hi Steve
Marcel
05-23-2012 05:30 AM
thanks again maurice !
