Customized Application Name
May 23rd, 2012
Hi all,
I see in the Medianet config guide this line
Router(config-cmap)# match application testapplication.
from the application name, it looks like Application names are configurable/ customizable. Is this correct? How? i don't see in the config guide how that can be done.
Would be great if you can also confirm how the switch will be able to match incoming data to one of the applications it learns from the network. Is this thorugh the the SSRC field?
Ahmed.
afahmy Wed, 05/23/2012 - 09:16
Thank you Eric. i have read the guide, but need to confirm the following:
Does the CLI match application allow the router/switch to lookup the metadata database using the Synchronization Source Identifier (SSRC) to identify the application type -which it learns thru metadata database and then applies the relevant policy...
Thanks, Ahmed.
Eric Yu Wed, 05/23/2012 - 13:17
Hi Ahmed,
CPL consumes metadata information stored in the  metadata table  by corelating the flow's 5 tuple information with  learned metadata attributes from the flow. SSRC is not used as this  value is limited to only RTP flows.
Flow metadata supports TCP as well as RTP sessions.
regards,
Eric
Related Content
